Hello Everyone,
Just got around to testing with the Taulman 645 and 618 I bought some time ago from Voxel Factory.
I was surprized to find the 645 was didn't fit at all in the 3 mm PTFE tube I use to guide filament out of the spool. Turns out the nylon is actually 3.13 mm, and the PTFE tube is 3.05mm.
I have the same PTFE tube in my hot end leading to the melt chambre, obviously, this is not going to work!
The spool of 618 is about 3.05 mm, and barely squeezes through the PTFE tube, so I'm printing a small test part right now.
Anyone know what is up here? Does nylon swell when it absorbs moisture?
Yvan
Singularity Machine
