Heated build chamber - Fridge? September 18, 2013 04:52AM |
Re: Heated build chamber - Fridge? September 18, 2013 06:00AM |
Re: Heated build chamber - Fridge? September 18, 2013 07:24AM |
Re: Heated build chamber - Fridge? September 18, 2013 07:55AM |
Re: Heated build chamber - Fridge? September 18, 2013 08:38AM |
Re: Heated build chamber - Fridge? September 18, 2013 10:21AM |
Re: Heated build chamber - Fridge? September 18, 2013 11:20AM |
Re: Heated build chamber - Fridge? September 19, 2013 06:25PM |
Re: Heated build chamber - Fridge? September 20, 2013 03:28AM |
Re: Heated build chamber - Fridge? September 20, 2013 06:41AM |
Re: Heated build chamber - Fridge? September 22, 2013 09:24AM |
Re: Heated build chamber - Fridge? September 22, 2013 07:31PM |
Re: Heated build chamber - Fridge? September 22, 2013 08:56PM |
Re: Heated build chamber - Fridge? September 23, 2013 07:21AM |
Re: Heated build chamber - Fridge? September 23, 2013 12:48PM |
Re: Heated build chamber - Fridge? September 23, 2013 01:28PM |
Re: Heated build chamber - Fridge? September 23, 2013 01:48PM |
Re: Heated build chamber - Fridge? September 23, 2013 03:13PM |
Re: Heated build chamber - Fridge? September 23, 2013 03:23PM |
Re: Heated build chamber - Fridge? September 25, 2013 03:48AM |
Re: Heated build chamber - Fridge? September 25, 2013 11:19AM |
Re: Heated build chamber - Fridge? September 25, 2013 03:31PM |
Re: Heated build chamber - Fridge? September 25, 2013 04:05PM |
Re: Heated build chamber - Fridge? September 25, 2013 04:18PM |
Re: Heated build chamber - Fridge? September 25, 2013 09:59PM |
Re: Heated build chamber - Fridge? September 28, 2013 10:48AM |
Re: Heated build chamber - Fridge? September 28, 2013 12:41PM |
Your chamber would probably top 100C and you would find puddles of molten ABS parts around your printer!|
Re: Heated build chamber - Fridge? September 28, 2013 05:10PM |
Re: Heated build chamber - Fridge? September 28, 2013 07:12PM |
Re: Heated build chamber - Fridge? September 28, 2013 08:18PM |
While ABS won't turn to liquid at 100C, if you pass it's glass transition temp (about 105C) it will get soft and will be much more susceptible to deformation due to printer movements. I wouldn't go above 80C just to be safe. Besides, if you can get the chamber temp up to 80C you definitely won't have any problems with ABS warping!
