Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 02:01PM |
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 02:15PM |
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 04:05PM |
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 04:38PM |
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 04:55PM |
Admin Registered: 16 years ago Posts: 730 |
bobc
They are enforceable only if the owner of the IP has the means to pursue an infringement claim.
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 05:20PM |
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 05:32PM |
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 05:36PM |
IanJohnson
If you are developing an all metal hot end, and license it NC, does that mean you are planning to sell them yourself?
bobc
But you can't pay someone else to make it for you, which is the point.
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 05:39PM |
I thought this was obvious so I did not think to mention it. As Traumflug already stated, any copy shop can go ahead and sell copies of an NC hardware design and the developer of said design will not even attempt to bring the copy shop to court because a) they won't have the time/money for this, and b) because the developer trusts the community to respect their work and it's intended use (NC). So far, the RepRap community seems to respect the licences that the developers release their work under, so the fact that the CC licences have no "legal teeth" with regards to hardware is irrelevant. The RepRap community is an amalgamation of developers who respect and support each other in their work. I think that if people in RepRap ever started to disrespect the intended use of a design (ie. NC) then developers would stop working within RepRap because the community will have lost it's morals/direction.Quote
MattMoses
So, trying to decide between NC or not NC for a hardware design is kind of a moot point - it doesn't matter either way because the CC license doesn't have any "legal teeth" when it comes to protecting the functional aspects of a hardware design.
I think you are overlooking key details in the distinction between "Open Source Software" and "Open Source Hardware". This distinction was articulated in the links I included in my last post, but I guess you did not care to view those pages as you clearly do not take this distinction into account. Put simply, the difference is in the costs and profits involved in development. The freedoms of Open Source are meant to be "Free as in free speech, not free beer".Quote
bobc
Open Source is a formally defined thing, it is not just a woolly concept that you or I might want it to be. All Open Source licenses allow "for any use". It is one of the defining features of Open Source that distinguishes it from Closed Source! No Open Source organisation will ratify a license as OS if it includes a "restriction on use" clause.
Mind you, I made some small mistakes along the way, but when you are working with hardware, small mistakes tend to cost a lot of money. After the cost of buying filament to test my design, I will likely end up spending even more on prototyping.
If I was only going to release the design, I would certainly release it under a GPL licence. Because I will have my hot ends professionally manufactured, an NC licence makes sense for several reasons, many of which I explained above. |
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 05:42PM |
bobc
Open Source specifically allows any commercial use
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 05:52PM |
OSHW Definition 1.0
In promoting Open Hardware, it is important to make it clear to designers the extent to which their licenses actually can control their designs. Under U.S. law, and law in many other places, copyright does not apply to electronic designs. Patents do. The result is that an Open Hardware license can in general be used to restrict the plans but not the manufactured devices or even restatements of the same design that are not textual copies of the original. The applicable section of copyright law is 17.102(b), which says:
In no case does copyright protection for an original work of authorship extend to any idea, procedure, process, system, method of operation, concept, principle, or discovery, regardless of the form in which it is described, explained, illustrated, or embodied in such work.
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 06:17PM |
RP Iron Man
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 06:54PM |
>Quote
bobc
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 07:00PM |
>Quote
bobc
> commercial use
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 07:22PM |
> I think you are overlooking key details in theQuote
bobc
> clause.
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 07:38PM |
The distribution terms of Open Source Hardware must comply with the following criteria:
1. Documentation
The hardware must be released with documentation including design files, and must allow modification and distribution of the design files. Where documentation is not furnished with the physical product, there must be a well-publicized means of obtaining this documentation for no more than a reasonable reproduction cost, preferably downloading via the Internet without charge. The documentation must include design files in the preferred format for making changes, for example the native file format of a CAD program. Deliberately obfuscated design files are not allowed. Intermediate forms analogous to compiled computer code — such as printer-ready copper artwork from a CAD program — are not allowed as substitutes. The license may require that the design files are provided in fully-documented, open format(s).
2. Scope
The documentation for the hardware must clearly specify what portion of the design, if not all, is being released under the license.
3. Necessary Software
If the licensed design requires software, embedded or otherwise, to operate properly and fulfill its essential functions, then the license may require that one of the following conditions are met:
a) The interfaces are sufficiently documented such that it could reasonably be considered straightforward to write open source software that allows the device to operate properly and fulfill its essential functions. For example, this may include the use of detailed signal timing diagrams or pseudocode to clearly illustrate the interface in operation.
b) The necessary software is released under an OSI-approved open source license.
4. Derived Works
The license shall allow modifications and derived works, and shall allow them to be distributed under the same terms as the license of the original work. The license shall allow for the manufacture, sale, distribution, and use of products created from the design files, the design files themselves, and derivatives thereof.
5. Free redistribution
The license shall not restrict any party from selling or giving away the project documentation. The license shall not require a royalty or other fee for such sale. The license shall not require any royalty or fee related to the sale of derived works.
6. Attribution
The license may require derived documents, and copyright notices associated with devices, to provide attribution to the licensors when distributing design files, manufactured products, and/or derivatives thereof. The license may require that this information be accessible to the end-user using the device normally, but shall not specify a specific format of display. The license may require derived works to carry a different name or version number from the original design.
7. No Discrimination Against Persons or Groups
The license must not discriminate against any person or group of persons.
8. No Discrimination Against Fields of Endeavor
The license must not restrict anyone from making use of the work (including manufactured hardware) in a specific field of endeavor. For example, it must not restrict the hardware from being used in a business, or from being used in nuclear research.
9. Distribution of License
The rights granted by the license must apply to all to whom the work is redistributed without the need for execution of an additional license by those parties.
10. License Must Not Be Specific to a Product
The rights granted by the license must not depend on the licensed work being part of a particular product. If a portion is extracted from a work and used or distributed within the terms of the license, all parties to whom that work is redistributed should have the same rights as those that are granted for the original work.
11. License Must Not Restrict Other Hardware or Software
The license must not place restrictions on other items that are aggregated with the licensed work but not derivative of it. For example, the license must not insist that all other hardware sold with the licensed item be open source, nor that only open source software be used external to the device.
12. License Must Be Technology-Neutral
No provision of the license may be predicated on any individual technology, specific part or component, material, or style of interface or use thereof.
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 08:01PM |
Now you are saying actually you can "make it and sell it".
"offering manufacturing services" is a commercial activity, which is prohibited by NC
it is not mine but everyones.
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 08:09PM |
MattMoses
You have this completely backwards. Developers come to RepRap to get ideas, advice, free technical support, and more.
When "people in RepRap" lose their "morals/direction" they don't stick around. Because they're too busy putting together their Kickstarter campaign and running their new company.
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 08:25PM |
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 08:26PM |
Perhaps, for reference it would be useful to include an Open Source Hardware definition.
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 08:28PM |
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 08:51PM |
The GPL does not require you to release your modified version, or any part of it. You are free to make modifications and use them privately, without ever releasing them. This applies to organizations (including companies), too; an organization can make a modified version and use it internally without ever releasing it outside the organization.
But if you release the modified version to the public in some way, the GPL requires you to make the modified source code available to the program's users, under the GPL.
Thus, the GPL gives permission to release the modified program in certain ways, and not in other ways; but the decision of whether to release it is up to you.
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 08:56PM |
bobc
Traumflug
The possible reasons why this definition doesn't work for everyone is exactly the topic here. Calling everything which doesn't match these criteria "closed source" or "not open" is a vast oversimplification, because you can't really call published sources "closed". Doing this simplification leaves no room between public domain and totally hidden, which clearly neither reflects reality nor the intentions of many RepRap developers.
Arduino, for example, doesn't match above criteria either. In opposite to clauses 4. and 8., they restrict derivates with their trademark.
Re: An internal struggle between the "we" and the "me" on the community and IP October 03, 2013 09:08PM |
NC projects generally become dead ends.
Re: An internal struggle between the "we" and the "me" on the community and IP October 04, 2013 05:28AM |
Re: An internal struggle between the "we" and the "me" on the community and IP October 04, 2013 09:15AM |
Re: An internal struggle between the "we" and the "me" on the community and IP October 04, 2013 02:56PM |
Re: An internal struggle between the "we" and the "me" on the community and IP October 04, 2013 05:18PM |
Re: An internal struggle between the "we" and the "me" on the community and IP October 05, 2013 11:12AM |
Hello open hardware fellows,
let me try to talk about this topic, which I found to be a pretty tricky one and in the hope I don't forget an important part.
I'm a developer in (and an admin of) the RepRap community, well known for bringing 3D printers to the masses. A great, big and reasonable healthy community.
RepRap has come to a point where many shops do business by mostly or solely just copying and selling existing designs. That's a multi-million dollar business these days, I count about 50 such shops worldwide and a new one about weekly.
Undoubtly, this is great for consumers. It's also great for those who develop as a hobby and make their living with another job and/or are one of many employees. It's still fine for those developers running their own shop (which happen do be quite a number).
But there's yet another group: pure developers. Those talented engineers and craftsmen, often self-employed, brilliant at designing something, but poor as a salesman. Of course, they need to bring food onto their table, too.
These pure developers struggle quite a bit with licencing their design with something like the current OHL. Because developing hardware costs not only substantial amounts of time, it also costs substantial amounts of money. We all know this. And there is no reliable way to get rewarded for these costs if everything is OHL'd and as such, quasi in the public domain.
To deal with this, they could also open a shop for their own products. But this needs time, typically a lot of time, which is lost for more development. And doing both, developing and selling is a substantial disadvantage over those who concentrate on just the selling.
It's said developers have a huge advantage over copy shops because there's their name on the design. Maybe the advantage is no longer as big if a design shows up in dozens of shops, none of them mentioning the name of the developer, or some shops even tack their own name onto the design (sort of rebranding). People simply forget who did the hard work.
To find better solutions, a few RepRappers are currently evaluating two things. One is a system to collect funding before the work. Like a number of people pledging a few euros each for fixing a bug or getting some detail improved. The developer bringing in the improvement gets the money. [bountysource.com] is an example of a site offering such a service.
[forums.reprap.org]
The other one is --now, please don't get upset-- to introduce/promote an open hardware licence with a non-commercial clause. Such a clause means: everybody can look at and learn from the sources, everybody can modify the design, everybody can make a copy, everybody can ask a machining shop to make a copy, everybody can make a derivate, all with one restriction: only the licence holder can _sell_ copies. Also those who make a contract separate from the licence, like a fee-based contract, of course.
Our discussion: [forums.reprap.org]
A licence similar to this is the Creative Commons BY-NC-SA which some RepRap developers use for the lack of a better one already:
[creativecommons.org]
We're aware this restricts freedom. But doesn't the GPL gently restrict freedom of software, too, and is very successful with this? The MIT/BSD licence has fewer clauses, more freedom and ... has a "market" share of perhaps of 10% of all open source projects while 70% is GPL'd or LGPL'd (my estimate).
In the same vein I could very well imagine preferring a non-commercial OHL could enhance, outright fuel open hardware development. Because technology doesn't advance on its own, it needs developers. And because a non-commercial clause doesn't hide anything, it just reduces merchantability for the favour of developers.
What do you think?
Markus
Re: An internal struggle between the "we" and the "me" on the community and IP October 05, 2013 05:56PM |
vegasloki
GPL explicitly defines use as private use
