Ideas to make printed parts -- Cosmetically Appealing --
Posted by willer2k
October 01, 2013 01:59PM
Hello!
I am attempting to make my 3d printed parts cosmetically appealing, hide the layers and path of the nozzle.
Any one has any clue how to achieve it relatively simply?
I have attempted some local paint supplier with their thickest paint, but no success. I tried some automotive pot putty, but it requires way to much work. Any ideas are welcome.
Thank You! smiling smiley
Re: Ideas to make printed parts -- Cosmetically Appealing --
October 01, 2013 02:16PM
October 01, 2013 06:33PM
dissidence Wrote:
> pla or abs.?
ABS, but I can switch to PLA if I have to.
October 01, 2013 06:42PM
i dont know about PLA but with ABS there are a few thing about brushing on acatone or a vapor bath.
[mike-mack.blogspot.com]
Google "acetone bath" for ABS smoothing.
October 02, 2013 04:47AM
willer2k Wrote:
> Hello!
> of the nozzle.
> simply?
Can you post a photo of one of your printed parts as an example?
Regards
Jan
[3dprinting4u.wordpress.com]
October 02, 2013 08:53AM
October 02, 2013 12:19PM
Fantastic, I think this will work.
Thank you guys so much! grinning smiley
October 02, 2013 03:08PM
Acetone vapor bath is one good way. Another is Dupli-color filler primer (automotive) it is like the paint method you tried but is designed to fill in deep scratches like the body filler. It goes on in a very heavy coat without dripping and is a neutral gray color that can then be painted.
I have used all of the methods, each has it's use. I like vapor bath for many projects but it does have a wavy melted candle look to it. When I make replica props I prefer the Dupli-Color filler primer instead as it's a much sharper, flatter surface.
[assets.farmandfleet.com]
October 03, 2013 10:21AM
Hey!
Does the primer stick to the ABS plastic? Will it peel off if scratched with fingernails?
This is definitely worth experimenting with.
Thank you so much for your input!! grinning smiley
