H bridge 2 parallel motors
October 11, 2013 04:40AM
Hi, everybody,
I want to add a second motor to the X motor. I want to put them in parallel, when I command one, the second is also commanded!!
Can I connect a second motor in parallel after the stepper driver. Or must I connect the command of arduino to a second stepper driver, and this to a second motor.
Re: H bridge 2 parallel motors
October 11, 2013 05:21AM
Well many RepRap machines have exactly that for the Z axis, two motors in parallel driven by one driver. So it should work for the X (or Y) axis as well.
David
October 11, 2013 05:28AM
Hi David,
Exactly!!
Think you so much!! I just need to put a radiator on the stepper driver!!
Thnik you!!
October 11, 2013 05:44AM
With two motors and one driver you cannot get max speed and torque out of your motors.
October 11, 2013 08:53AM
Depends on how much current you need. If the driver can spend enough for both, it works. Typically Pololus can't max out steppers anyways, it's always a matter of sufficient torque.
That said, one can run two Pololus in parallel, too. Apply the same Step and Dir signal to both and they should behave identical.
