Need help printing Taulman Nylon 618
October 12, 2013 03:21PM
Hi all,
i'm trying to print Taulman Nylon 618 and have a real problem getting it to stick to anything.
So far i tried Aluminium with Water/Woodglue, Wood, PEI, paper, printing temperature is 245°C,
The best so far is wood, it only sticks for less than 5 minutes though.
Any experience what does work?
Cheers
Björn
PS: add aluminium with PET sad smiley
Edited 1 time(s). Last edit at 10/12/2013 03:23PM by Srek.
[www.bonkers.de]
[merlin-hotend.de]
[www.hackerspace-ffm.de]
Re: Need help printing Taulman Nylon 618
October 12, 2013 03:52PM
[forums.reprap.org]
Detlef
Excalibur Hotend
reprapzone.blogspot.de
October 12, 2013 03:54PM
Isn't that the same as the glue mixture i already tried? That one works fine for laywood, laybrick and FPE, but not at all with Nylon 618.
Did it realy work for you?
October 12, 2013 04:33PM
I have heard cardboard used. Vaguely remember that porosity helps.
October 12, 2013 04:34PM
Sorry i forgot to mention that, i already tried cardboard as well.
October 12, 2013 08:39PM
I had great success with the brand UHU non toxic glue stick, smear a thin layer on,
I also used non heated bed, also uhu glue on blue painters tape worked well..
hows it like to extrude? any crackle and pop sounds? might need bed readjustment or slow down first layer more...
October 12, 2013 08:59PM
I print on the back side of Copper clad PC board material (fiberglass I think. The light brown kind). I had some single sided and tried it and it works good but you need a heated bed (I set mine to 85c) and make sure the nozzle is close as you want it to really smash the nylon into the board, first layer should be barely visible (looks like a thin wax film) then the rest will print fine. The nice part is it sticks very well while heated but just pops of once cooled.
