Hi Brian,
... around 2001 i developed a mikro-dispenser which is capable of placing single droplets of high viscous fluids or pastes in sizes down to submicron-range - apended an image with an array of 30 micron big droplets in a grid of 100 microns displacement.
The droplet down right is bigger beacause here i placed 3 droplets one on the other.
It's patented too, but nobody really wanted this technology then - it was much to fine for the current needs in 2002
In combination with conventional dispensers for fluids and pastes, extruder for the housing and solids and maybe some other tools (dremel, gripper, vacuum/pick'n'place, ...) for the assembly you should be able to build any structure with an accuracy down to microns (or even finer
Viktor
