Hot end dimentions
October 20, 2013 04:33PM
I want to make an extension for my hot end but do not know what size of drill bit to get for 1.75mm filament. I was reading THIS page and the PTFE liner they use is 3/32 and it looks like the J-Head's use a liner with 1/8" ID.
What is the best size to drill through my 6mm rod so I do not need a liner??
Re: Hot end dimentions
October 20, 2013 04:47PM
2mm for 1.75mm and 1/8th for 3mm
-=( blog )=- -=( thingiverse )=- -=( 3Dindustries )=- -=( Aluhotend - mostly metal hotend)=--=( Facebook )=-
October 21, 2013 10:39PM
1/8th being 1/8th of an inch, or 3.175mm.
October 21, 2013 11:17PM
October 22, 2013 07:05AM
Stainless steel seems to be the choice nozzle material for all metal hot ends but it is a pain to machine. I can do brass, aluminum and steel. Which one would be the best second choice?
Also because stainless has such a low heat conduction you can get away without a PTFE liner, if I change to another metal do you think I should even bother making one without a liner or am I asking for trouble?
Edited 1 time(s). Last edit at 10/22/2013 07:06AM by uMinded.
