slic3r scale help!!
November 02, 2013 12:26AM
I made an model using 3ds max, and export it into an stl file, but when I opened it using slicer, the scale was completely off. The model size was also much smaller when I opened it with slic3r. What is wrong?
open | download - 123.png (50 KB)
Re: slic3r scale help!!
November 02, 2013 01:29AM
Is everything in mm?
November 02, 2013 03:02AM
It´s the same with blender I guess. Even if you use blender units or meter in blender as soon as you save as .stl it gets shrunk by faktor 10. So in slicer I scale by 1000% and then its normal size.
November 02, 2013 04:34AM
I use Blender, set to metric units and I do the scaling up within it. For example, if I want a cube with 20mm sides, in Blender I set it to have 20m sides. This way you minimise software arithmetical errors.
Harvey
A2
November 02, 2013 07:57AM
Why does 3DS MAX, and Blender rescales the .STL data file?
Any other CAD software doing this?
November 02, 2013 09:34AM
problem solved. I only changed display unit to mm but forgot to change system unit to mm.
November 18, 2013 06:16AM
dw1991
thanks for the info, this might be my problem too. I'm using inventor, and all files are scaled by 0.1.
