Y endstop not working correctly
Posted by Ickis
November 02, 2013 04:01AM
So the really short version:
- Running Marlin on RAMPS 1.4.
- The Y axis will move in both directions.
- If the end stop is pressed the Y axis will still move towards the endstop but will not move away. (ie. it thinks the endstop is on the opposite end of the axis)
- Changed the endstop homing direction in Marlin but it still does the same thing?
// ENDSTOP SETTINGS:
#define X_HOME_DIR -1
#define Y_HOME_DIR 1
#define Z_HOME_DIR -1
Am I missing something or is there a bug in Marlin where the Y home direction does not actually change even if the setting is?
Re: Y endstop not working correctly
November 02, 2013 06:15AM
Nevermind. Figured it out.
Had to move the endstop connection one set of pins up to the Y+ connectors on the RAMPS board.
Learning so much from this printer.
