Hello,
I have a printer with two extruders (X 400). I want to use extruder 1 for ABS (temp 260) and extruder 2 for PLA. Extruder 1 is supposed to print the peremeters in ABS and extruder 2 is supposed to print the fillment and support. For the extruder have to handle two different temperatures I am struggeling. Normally I am using CURA , which normally works fine but has no switch to have the fillment printed with the second extruder. Instead I switched back to RepetierHost and slic3r which offers this possibility but doesn't give me the opportunity to have two different temperatures.I am using Marlin (has to be for I am using a LCD controller with card ). So I guess I have to alter the start g-code. Does anybody has a clue what would be the code to have extruder 1 on 260 and extruder 2 on 210,permanently? I already tried with G10 R 150 S 210 S1 but read somewhere ( after failure ) that Marlin doesn't know the G10 code. Please help.
Regards, Frank
