I just shot off a trouble ticket to Microchip about my 18F4610 PIC. I'm pasting a copy of what I told them here to see if any of you have run into this kind of problem with other PIC chips.
I've been using the 18F4610 very successfully in a controller board project for some months now. Yesterday, I noticed the L7805CV voltage regulator that creates +5v power for the chip was overheating. I unplugged all of the IC chips from the board and the overheating stopped. I then started looking for the source of the problem and it happens that the 18F4610 chip was heating up when it was plugged into the board. At that point I started looking for potential shorts on the board and didn't find any.
I finally started checking the 18F4610 chip itself and discovered that for the two of these chips that I had been using the resistance between VSS (pin 31) and VDD (pin 32) was between 10-15 ohms. I got a fresh 18F4610 chip out of my inventory and discovered that the resistance between VSS and VDD was a bit above 4.7K ohms. I plugged the fresh 18F4610 chip into the board and powered it up and there was no overheating.
Do you have any idea how this could have happened? If I hadn't accidently put my finger on the voltage regulator and discovered that it was blazing hot I would have never noticed the problem. The 18F4610 chips were otherwise performing quite well and I was communicating with them via the UART serial link.
Is this a chip failure or is there some way that I could have treated the chips to have cause this sort of behaviour?
If anybody has either had this sort of experience or heard of it before I'd appreciate hearing from you. I'm rather baffled. I suspect that I did something wrong, but I'm at a loss to know what it is.
Hell, there are no rules here - we're trying to accomplish something.
Opportunity is missed by most people because it is dressed in overalls and looks like work.
Thomas A. Edison
