Re: RadRacer builds a "BerryBot3D" January 01, 2014 11:49AM |
Re: RadRacer builds a "BerryBot3D" January 01, 2014 12:00PM |
Re: RadRacer builds a "BerryBot3D" January 01, 2014 01:31PM |
Re: RadRacer builds a "BerryBot3D" January 01, 2014 03:35PM |
Re: RadRacer builds a "BerryBot3D" January 02, 2014 02:05AM |
Re: RadRacer builds a "BerryBot3D" January 04, 2014 02:14AM |
Re: RadRacer builds a "BerryBot3D" January 04, 2014 12:26PM |
Re: RadRacer builds a "BerryBot3D" January 05, 2014 09:08PM |
Re: RadRacer builds a "BerryBot3D" January 05, 2014 09:44PM |
Rad Racer
Sorry guys....I don't have the STL files, Warner sent me the direct drive assembly for my machine.
The stepper can be purchased at www.stepperonline.com.
Re: RadRacer builds a "BerryBot3D" January 06, 2014 12:33AM |
Re: RadRacer builds a "BerryBot3D" January 06, 2014 02:48AM |
Re: RadRacer builds a "BerryBot3D" January 06, 2014 08:07AM |
Re: RadRacer builds a "BerryBot3D" January 11, 2014 06:10PM |
Re: RadRacer builds a "BerryBot3D" January 12, 2014 02:56PM |
Re: RadRacer builds a "BerryBot3D" January 13, 2014 05:02AM |
Re: RadRacer builds a "BerryBot3D" January 25, 2014 07:01PM |
Re: The "BerryBot3D" is up and running. January 26, 2014 04:43PM |
Re: RadRacer builds a "BerryBot3D" January 26, 2014 04:59PM |
Re: RadRacer builds a "BerryBot3D" January 29, 2014 08:03AM |
Re: RadRacer builds a "BerryBot3D" February 10, 2014 08:52PM |
Re: RadRacer builds a "BerryBot3D" February 17, 2014 01:07PM |
Re: RadRacer builds a "BerryBot3D" February 17, 2014 01:27PM |
Re: RadRacer builds a "BerryBot3D" February 19, 2014 02:54PM |
Re: RadRacer builds a "BerryBot3D" February 19, 2014 07:00PM |
Re: RadRacer builds a "BerryBot3D" February 20, 2014 01:14AM |
garyhlucas
New,
If you 3D model a Berrybot for a build size like you said you will find out that you can't enclose the triangle without losing a huge amount of your built area. So to get the size you want with 3 towers and enclosed it won't fit through a standard 36" door opening! Just a thought.
Re: Re: RadRacer builds a "BerryBot3D" February 21, 2014 01:19PM |
Re: Re: RadRacer builds a "BerryBot3D" February 21, 2014 05:04PM |
garyhlucas
New,
You want a big build envelope for big parts. So it is likely you'll need an enclosure to control temperature. So you will find that you either need to put the three columns very far apart or make your enclosure a hexagon. My calculation comes from the 3d model I've done in Solid Works for the printer I am building. This one is for a friend and if it comes out well I hope to sell just the machined parts with my grandson so others could build them this way. There is no welding, and using T-slot extrusions it can be scaled up or down.
Re: Re: RadRacer builds a "BerryBot3D" February 21, 2014 06:31PM |
Re: Re: RadRacer builds a "BerryBot3D" February 21, 2014 06:40PM |
Re: Re: RadRacer builds a "BerryBot3D" February 22, 2014 02:29AM |
garyhlucas
By the way. You want to do 3D printing. Unless you want to only print stuff other people designed then you are going to need a program to produce 3D models. So really that should be your first purchase not the last. If you get that first you will be able to answer all your questions before you build stuff that won't work at all. "Ooh, if I had just made that part a 1/4" shorter the left over material could have made part B instead of buying another whole length I don't really need!" By time you actually get around to printing you will know enough to be able to model what you want. As you are building you may need parts you can't make. Drawings are the language that manufacturers speak. The more you can tell them about a part you need the likely cheaper it will be to have made. Better to find out your 'simple' part is going to cost $500 before you have a half built printer and can't finish!
So a 3D modeling program purchased first is likely to save you money. It's funny how often the what I have in my head can't actually be made in the real world!
