firing circuit for SCR
Posted by hasan081043
November 26, 2013 05:42PM
i want to work with thyristor .please suggest some firing circuit for thyristor.
Re: firing circuit for SCR
November 27, 2013 02:53AM
are you sure it's thyristors you're interested in? thyristors are for switching AC voltages.
You may want to use a MOSFET - these can switch DC. I recently used a N-channel MOSFET, a P30N06LE worked well for me... these can handle 30 amps at 60 volts with a proper heatsink! They only drop 1 volt across the source/drain which is quite nice.
Have a look on google for simple MOSFET circuits! there are millions
And if you DO want to switch AC voltage... use a triac spinning smiley sticking its tongue out
November 27, 2013 10:15AM
also if using a triac, also use a traic optocoupler. it isolates the electronics, and allows function even with uneven ac loads.
