Spiral Vase Z lift problem on mendel90 December 04, 2013 01:49PM |
Re: Spiral Vase Z lift problem on mendel90 December 04, 2013 02:26PM |
dagusi
Sorry but I don't know if there it's a better place to ask this.
I have a mendel90 variation printer with ramps 1.4 on an arduino UNO and 4 pololous a4988, I'm running marlin on the arduino and repetier host on the PC (I dont have the SD reader, it's on the way from china)
I usually use KISslicer for my gcode but some models and single wall spiral vases are sliced on slic3r, works better.
All my print are comming out great but today I did my first Vase and one of the 2 Z steppers does not rotate properly, anyway if I do any motion it works great from the manual control on repetier host, but on the spiral is skips steps, but the other stepper goes on and both are connected to the same A4988. MEchanically everything it's ok, all part work great and on manual moves everything moves properly, running the G code fails.
I don't know where to look for the problem really, no clue.
someone have had the same problem? or any ideas? wires are ok, connections are ok, motor and driver are cold when running. mechanics are smooth.
Re: Spiral Vase Z lift problem on mendel90 December 04, 2013 03:53PM |
Re: Spiral Vase Z lift problem on mendel90 December 04, 2013 07:02PM |
Re: Spiral Vase Z lift problem on mendel90 December 05, 2013 07:27AM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Spiral Vase Z lift problem on mendel90 December 09, 2013 11:56AM |
Re: Spiral Vase Z lift problem on mendel90 March 15, 2014 09:49AM |
Re: Spiral Vase Z lift problem on mendel90 March 15, 2014 12:40PM |
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
