Filament diameter - differences between 1.75mm and 3.0mm December 10, 2013 07:17AM |
Re: Filament diameter - differences between 1.75mm and 3.0mm December 10, 2013 08:05AM |
Re: Filament diameter - differences between 1.75mm and 3.0mm December 10, 2013 08:40AM |
Re: Filament diameter - differences between 1.75mm and 3.0mm December 11, 2013 05:08AM |
Re: Filament diameter - differences between 1.75mm and 3.0mm December 12, 2013 03:08PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm December 12, 2013 03:15PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm December 12, 2013 04:58PM |
Admin Registered: 11 years ago Posts: 1,063 |
Yvan
I'm still on the lookout for any evidence that one is better than the other.
If anyone has anything substancial, I'd love to see it.
Re: Filament diameter - differences between 1.75mm and 3.0mm December 12, 2013 05:27PM |
thejollygrimreaper
Yvan
you probably won't find any/much that is valid,
Re: Filament diameter - differences between 1.75mm and 3.0mm December 12, 2013 05:45PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm December 12, 2013 08:35PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm December 12, 2013 10:16PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm December 13, 2013 05:03AM |
Re: Filament diameter - differences between 1.75mm and 3.0mm December 13, 2013 12:28PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm December 13, 2013 01:08PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm December 13, 2013 02:34PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 10, 2014 12:01PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 10, 2014 02:01PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 10, 2014 03:23PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 10, 2014 04:01PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 10, 2014 04:29PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 10, 2014 04:47PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 10, 2014 07:44PM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 11, 2014 12:14AM |
T3P3
The proper J heads made by Brian at RPW are machined differently to suit the filament diameter. I have found the clones that use inserts to be very unreliable. See Brain's blog post on the subject: [jheadnozzle.blogspot.com]
[blog.think3dprint3d.com]
Re: Filament diameter - differences between 1.75mm and 3.0mm January 11, 2014 12:34AM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 11, 2014 05:20AM |
NormandC
Ohmarinus
Just went to buy the E3D, but it's suddenly much more expensive (why?) so I can't buy it now. Too bad.
Actually you missed the Holidays sale. The E3D was 20% off and is now back to its regular price.
Re: Filament diameter - differences between 1.75mm and 3.0mm January 11, 2014 08:14AM |
Re: Filament diameter - differences between 1.75mm and 3.0mm January 12, 2014 02:13PM |
T3P3
The diameter of the filament does not have a direct influence on the extrusion force at the nozzle as the plastic is molten. It can make a difference further up the path though. It varies by hotend design for example the length of the transition zone.
The biggest reason to go for 1.75 from a techical standpoibt is that Bowden setups work (much) better, at least in my experience but I have only tried one 3mm rostock. This is because of the additional bending forces. On the downside TPE is a bit springer at 1.75 which makes that harder to print.
From a practical reason as 3mm becomes less popular less filament variety will probably be available in 3mm
Re: Filament diameter - differences between 1.75mm and 3.0mm January 12, 2014 05:33PM |
Ohmarinus
Would a 0.5mm nozzle still work well with 1.75mm filament? 0.35mm nozzles give a lot less extrusion, I'm a bit keen on keeping a 0.5mm nozzle size!
Re: Filament diameter - differences between 1.75mm and 3.0mm January 13, 2014 02:15AM |
I have been using 1.75 mm filament with nozzle diameters between 0.75 mm and 0.2 mm. It works fine and i expect the 1 mm nozzle i want to try to work just as well.Quote
Ohmarinus
Re: Filament diameter - differences between 1.75mm and 3.0mm January 13, 2014 11:07AM |
