MOSFET STP55NF06L
December 18, 2013 08:31AM
Which MOSFET is equivalent with MOSFET STP55NF06L !!!؟؟؟
Edited 1 time(s). Last edit at 12/18/2013 10:45AM by raranjbar.
Re: MOSFET STP55NF06L
December 18, 2013 09:03AM
Just curious, why do you need an equivalent mosfet? there are lots of STP55NF06 on eBay, Mouser, etc. cheap too... [www.ebay.co.uk]
What are you using the MOSFET for? if it's for a DC heated bed (below 60V!) I've used a P30N06LE (60v,30A N-channel) which has worked very well for me.
Cheers,
Tom
December 18, 2013 10:46AM
T0mmm
Cheers,
Tom
Thanks, because my country is Boycott.
I can provide MOSFETS form series 2SK and IRF Such as 2SK2800.
This is data sheet STP55NF06L
Edited 2 time(s). Last edit at 12/18/2013 10:57AM by raranjbar.
December 18, 2013 10:55AM
Do you confirm this mosfet IRLB8743PBF
December 18, 2013 05:52PM
The voltage on that one is lower (30v) so that should not be an issue and the amperage / wattage is higher and that's a good thing.
December 20, 2013 06:22PM
"Best mosfets for driving your heated bed: IRLB3813, IRLB8743, FDP8870, AOT240L, CSD18502KCS. These mosfets will run merely warm with NO heatsink and a load current of 10A. They should be good to over 15A with no heatsink according to the worst-case numbers in their datasheets and is also see also [reprap.org]"
From the irc bot
December 23, 2013 01:33PM
Yup I used IRL8743 there is no heat dissipation there works very fine purchased from RS components
Enjoy life smiling smiley
December 26, 2013 08:55AM
Consider using a car solenoid, a bit clicky in bang bang mode, but cheap and easily available. The coil on a solenoid can be driven with a relativly low current device.
December 26, 2013 07:24PM
Solenoids are relays are bad for high current, the mechanical connections arc and eventually weld themselves together..
December 27, 2013 05:19AM
They, as any other part, should be good up to the currents they are rated for. There are commonly used solenoids that can take hundreds of amperes, like the one used in electric starters of car engines.
