Prusa I3 Rework December 31, 2013 08:27PM |
Re: Prusa I3 Rework January 01, 2014 09:12AM |
Re: Prusa I3 Rework January 01, 2014 01:31PM |
Re: Prusa I3 Rework January 01, 2014 07:55PM |
Re: Prusa I3 Rework January 01, 2014 09:12PM |
WOW, thank you so very much for such a detailed explanation but I do not understand, yet, what you were saying about the M3.Quote
vegasloki
The set screws are typically M3-.5 x 8 mm and are for the pulleys. There are three, one for the extruder drive, one each for each motor as it corresponds with the printed parts BOM. If you are using metal pulleys the set screws are usually included and are also M3 X 8 BUT I've gotten a couple of shipments with slotted heads instead of socket heads. The M8-1.25 x 20 mm set screw is the extruder idler. The 35 mm socket head cap screws can be used in a few places as can the 40 mm screws. Typically the extruder or X carriage mounts depending on the build.
The only part that stands out on a rework build is the M3 x 60 mm screw. It's a a bear to find in the US and I don't know that it needs to be that long. It's used as the extruder idler tensioner. I buy several thousand fasteners a month from the biggest distributors in the US and the 60 mm was tough to find and was only available to me as a hex head without ordering from overseas. For those sets I've been including M3 x 45 and recommending springs to match. I haven[t yet printed one of the extruders but it seems that 45 mm is enough with the matching spring. Those that want a 60 mm can use a 4-40 machine screw 2 1/2" with matching nuts for the approximate metric equivalent.
Re: Prusa I3 Rework January 03, 2014 08:48AM |
Dark Alchemist
vegasloki
Thank you so much and when I start building this I will understand then I bet.
Re: Prusa I3 Rework January 03, 2014 12:07PM |
As far as "as you've been told by multiple people on IRC" I posted this thread before I was told and it is always nice to get the viewpoints and knowledge from people who would never step foot into IRC.Quote
tjb1
Dark Alchemist
vegasloki
Just like your other post about this...M3 is metric, 4-40 is standard, 4-40 is a roughly the same size as M3. Like you've been told by multiple people on IRC, you can either source your parts from McMaster and get what the list says or you can work with what you have and source metric/inch together. As much as you tried to save on washers I don't know why you would want to source something like this from a hardware store when it's going to be much cheaper at McMaster. First off, anything Metric or anything in a drawer in the hardware aisles at Lowes/Home Depot is overpriced. They charge like $1.50 for 5 washers when you can go to the drawers and get 15-20 of the "standard" ones for $1.50.
Re: Prusa I3 Rework February 20, 2014 08:23PM |
Well, I made my extruder today (hobbed bolt came in) and I can't find a place for a m3-0.5x60mm locally and I don't even have a place for 1/8" or a M4 x 2-2.5 inches locally. I will have to see if there is a fastener place around here that will sell me only two bolts/washers/nuts but most of them wat to sell hundreds.Quote
vegasloki
Re: Prusa I3 Rework February 25, 2014 04:49AM |
Re: Prusa I3 Rework February 25, 2014 10:20AM |
This is spot on - [reprap.org]
