Need help with my code
Posted by usernate28
January 04, 2014 03:30PM
I am having trouble with the x axis moving while printing. it works fine manually moving it but when printing it doesnt move but the print just shifts left. i uploaded the code i am using any help would be appreciated as i and a noob
Edited 1 time(s). Last edit at 01/04/2014 05:28PM by usernate28.
open | download - Configuration.h (14.6 KB)
Re: Need help with my code
January 05, 2014 05:25PM
So homing is working?
EDIT: I find that if I try move things too fast it messes up, or doesn't move at all. Try use some really slow print speeds. 30mm/sec (1800mm/min) is a good starting point. Also make sure you have the steps per mm set correctly.
Edited 1 time(s). Last edit at 01/05/2014 11:05PM by TheTechnicalNoob.
