home made pcb heated bed? January 09, 2014 04:01AM |
Re: home made pcb heated bed? January 09, 2014 06:03AM |
Re: home made pcb heated bed? January 09, 2014 06:08AM |
Re: home made pcb heated bed? January 09, 2014 07:06AM |
clack
I might be wrong but If you are using a switching supply I am sure the power wastage is negligable compared to the watts you are using for the head bed and I am thankfull not to use mains as it is so easy to make a mistake!
Re: home made pcb heated bed? January 09, 2014 08:47AM |
Re: home made pcb heated bed? January 09, 2014 11:26AM |
Re: home made pcb heated bed? January 09, 2014 11:30AM |
Re: home made pcb heated bed? January 09, 2014 05:37PM |
Re: home made pcb heated bed? January 09, 2014 08:40PM |
aduy
well i can produce the pcb traces at whatever width I want, and I also understand that the insulation on top of the pcb would need to be something thats hard to scratch away, perhaps some high temperature paint. also I could add a fuse inline with it.
ok well if the mains is too volatile for a home made pcb, has anyone used a higher voltage supply like 48v to power a heated bed, you could use thinner wires, right now with my 12" bed im running 2 pairs of 14ga copper wire to the bed and they get barely warm, with one pair of 14ga wires they get quite hot. if i run the bed on 48v then I could get away with 1/4 the thickness, compared to 12v.
