When your machine stops extruding...is it a clog hotend or the extruder motor just stops?
What size of nozzle do you have installed 0.2,0.3, 0.4...ect...make sure you update the nozzle size in your slicer software.
Suggestion: double check your settings match the machine nozzle size.
Is your extruder calibrated? ie: when you tell it to extrude 10mm through software the machine feeds 10mm? If your trying to push too much plastic through the nozzle it's possible for the melted material to be pushed up the wrong direction towards the cold end of your extruder then it solidifies and jams your extruder.
Suggestion: double check your calibration
Nozzle could be too close to the table it's possible for the melted material to be pushed up the wrong direction towards the cold end of your extruder then it solidifies and jams your extruder.
Suggestion:Try increasing the first layer height
Also temps are very important to jamming and skipping. Make sure you have the correct sensor selected in your FW
What material are you using?
