What's better on z-axis? Belts or leadscrews? January 09, 2014 04:52PM |
Re: What's better on z-axis? Belts or leadscrews? January 09, 2014 05:12PM |
Re: What's better on z-axis? Belts or leadscrews? January 09, 2014 06:50PM |
Re: What's better on z-axis? Belts or leadscrews? January 09, 2014 07:06PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: What's better on z-axis? Belts or leadscrews? January 09, 2014 07:51PM |
Re: What's better on z-axis? Belts or leadscrews? January 09, 2014 08:14PM |
Re: What's better on z-axis? Belts or leadscrews? January 09, 2014 08:46PM |
Re: What's better on z-axis? Belts or leadscrews? January 09, 2014 09:08PM |
Re: What's better on z-axis? Belts or leadscrews? January 09, 2014 09:48PM |
jpan
I see.. In my case( Phoenix ) the carriage does drop but is not a big deal, right?
I searched and found that Tantillus uses a leadscrew for z-axis. Maybe you got an older version? Anyways I guess I'll have to accept the resolution.. Maybe it's not that bad as I thought aha?
Re: What's better on z-axis? Belts or leadscrews? January 09, 2014 09:50PM |
aduy
hmm no z wobble you say? I might have to look into this for my machine, how many belts would it take hold a large heated bed, 18". I bet i could work out some sort of pulley system to increase the accuracy and distribute the load.
Re: What's better on z-axis? Belts or leadscrews? January 09, 2014 10:16PM |
Re: What's better on z-axis? Belts or leadscrews? January 09, 2014 10:28PM |
aduy
I think the best way for my printer would be with a few reductions using a length of spectra line with a high load capacity. or another thought, what if you had a single threaded rod that ran the same length as the z axis, however it is not connected directly to the bed, instead the threaded rod has one nut and that nut is attached to the belts or spectra line, which is then routed through pulleys to hold up the z axis. then you get the torque of a threaded rod with zero wobble because the threaded rod is not connected to the z axis directly.
Re: What's better on z-axis? Belts or leadscrews? January 09, 2014 11:25PM |
Re: What's better on z-axis? Belts or leadscrews? January 10, 2014 02:33AM |
Re: What's better on z-axis? Belts or leadscrews? January 11, 2014 11:12AM |
Re: What's better on z-axis? Belts or leadscrews? January 11, 2014 12:42PM |
jpan
HI Sublime,
So you are the creator of Tantillus? Why did you close your store?
Re: What's better on z-axis? Belts or leadscrews? January 11, 2014 01:05PM |
Re: What's better on z-axis? Belts or leadscrews? January 11, 2014 02:11PM |
jpan
Hum that's a pity.
I'm curious. Are you guys who have your own design all professional? I mean, do you all have engineering background?
Re: What's better on z-axis? Belts or leadscrews? January 12, 2014 09:17AM |
Re: What's better on z-axis? Belts or leadscrews? January 12, 2014 08:13PM |
Re: What's better on z-axis? Belts or leadscrews? January 13, 2014 06:40PM |
