Frame materials
January 12, 2014 11:40AM
I am currently building a Prusa i3 and I have a question in terms of materials for the frame and print bed. I have seen MDF and Aluminum used for the frame and bed. Does anyone have any knowledge or advise as to if these parts can be created with Plexiglass? Thanks.
d
Re: Frame materials
January 12, 2014 05:59PM
I would not recommend using plexiglass as it becomes bendy when it heats up and you would need to use a thick variant to get the kind of stiffness one would desire.
My best experiences are still with aluminum..
With MDF I'm also not completely satisfied, but when you don't have a choice, it is a good idea to use MDF plate thats at least 6mm thick.
As far as printing directly on plexiglass/acrylic goes... Don't do it. Your plastic will stick to the bed and you cannot get it off again. Also the plexiglass will deform and become bobbly.
Anonymous User
Re: Frame materials
January 12, 2014 06:19PM
Depends on the thickness. 6mm or below is probrably going to be too wobbly.
Re: Frame materials
January 13, 2014 07:54PM
I would not use plexiglass first of all it's a little flexible second it tends to crack especially around any mounting points. Many early 3-D printers tried to use this and they all had problems cracking with this as frame material. It looks cool but that's about it
