Implementing an Auto-Leveling Bed? (link) January 14, 2014 02:17PM |
Re: Implementing an Auto-Leveling Bed? (link) January 14, 2014 05:06PM |
Re: Implementing an Auto-Leveling Bed? (link) January 15, 2014 03:11PM |
Re: Implementing an Auto-Leveling Bed? (link) January 15, 2014 03:13PM |
Re: Implementing an Auto-Leveling Bed? (link) January 15, 2014 03:35PM |
Re: Implementing an Auto-Leveling Bed? (link) January 15, 2014 08:49PM |
Re: Implementing an Auto-Leveling Bed? (link) January 26, 2014 07:05PM |
Re: Implementing an Auto-Leveling Bed? (link) January 26, 2014 11:07PM |
Re: Implementing an Auto-Leveling Bed? (link) January 26, 2014 11:43PM |
umdpru
Check out zenmasters videos.
[m.youtube.com]
They are for a makerfarm prusa i3 but the ramps part and firmware videos will be very helpful.
He answers ask your questIons in his three videos. I got my bal done with the help of his videos.
Re: Implementing an Auto-Leveling Bed? (link) January 27, 2014 09:37AM |
Re: Implementing an Auto-Leveling Bed? (link) January 29, 2014 01:26PM |
jamesdanielv
brnrd:
the auto bed routing is performed by G29, it needs to be performed after G28 otherwise all settings are lost.
also i had some signal issues with my servo jerking back a bit whenever my extruder motor stopped. i fixed it by driving the pulse width pin to high when servo is not in use. I have my servo wires routed thru with my extruder wires to keep things neat, so this solves issues with cross talk over wires longer than 6inches
Re: Implementing an Auto-Leveling Bed? (link) January 29, 2014 03:29PM |
Re: Implementing an Auto-Leveling Bed? (link) January 29, 2014 03:53PM |
kfootball15
jamesdanielv
brnrd:
Hmm not sure I understand. What do you mean by G29 and G28?
Re: Implementing an Auto-Leveling Bed? (link) January 29, 2014 09:38PM |
brnrd
kfootball15
jamesdanielv
brnrd:
Read the wiki.
Re: Implementing an Auto-Leveling Bed? (link) January 30, 2014 08:09AM |
jamesdanielv
brnrd:
Re: Implementing an Auto-Leveling Bed? (link) February 07, 2014 01:42PM |
Re: Implementing an Auto-Leveling Bed? (link) February 07, 2014 05:34PM |
brnrd
Is the automatic bed routine performed using G28?
Re: Implementing an Auto-Leveling Bed? (link) February 07, 2014 05:43PM |
kfootball15
Im having a little trouble. I have the software edited and I'm pretty positive I have that part is correct.
When I go to pronter face and type in the command "M280 P0 S150" to get the servo to move, nothing happens.
That is most likely because I have not jumped the servo pins. I really don't know how to do that. Do I just take a wire and touch one to the 5V pin and the other to the VCC pin? I've tried that but nothing happened.
Help is much appreciated!
Thanks
Re: Implementing an Auto-Leveling Bed? (link) February 07, 2014 05:45PM |
kfootball15
brnrd
kfootball15
jamesdanielv
brnrd:
Read the wiki.
Check out this part of the forum [forums.reprap.org]
These issues have been dealt with in detail.
You will need to set the speeds of your Z movement.
Great thank you!
Last question!
I am able to move my probe to the degree I need it to, but now my z-axis is freaking out. It goes up and down and makes a loud noise. It worked perfectly before installation, and works perfectly as soon as I remove the jump.
ANy idea?
Re: Implementing an Auto-Leveling Bed? (link) February 07, 2014 06:22PM |
Re: Implementing an Auto-Leveling Bed? (link) February 07, 2014 06:41PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Implementing an Auto-Leveling Bed? (link) February 11, 2014 09:31AM |
Isamu2040
How can I do to add more proving points?
Marlin only lets you define left, right, back and front values. In my case I would like to establish a grid of nine or maybe more point, hoy can I add those values?
Re: Implementing an Auto-Leveling Bed? (link) February 11, 2014 11:50AM |
Re: Implementing an Auto-Leveling Bed? (link) February 16, 2014 01:11PM |
jamesdanielv
quote 'James, how did you drive the pin high to disable the servo when not in use?'
i look for the modifications tonight.
-still need to look, it was a few lines in the initialization of the servo, once servo is disconnected, i set pin high. this prevents noise from jittering the servo position.
again i'll look at it when home tonight.
Re: Implementing an Auto-Leveling Bed? (link) February 16, 2014 03:55PM |
Re: Implementing an Auto-Leveling Bed? (link) February 17, 2014 12:24AM |
Re: Implementing an Auto-Leveling Bed? (link) February 17, 2014 12:37AM |
Re: Implementing an Auto-Leveling Bed? (link) September 16, 2014 08:55PM |
Re: Implementing an Auto-Leveling Bed? (link) September 16, 2014 10:51PM |
