J-head with ceramic body instead of PEEK January 15, 2014 02:39PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: J-head with ceramic body instead of PEEK January 15, 2014 02:56PM |
Re: J-head with ceramic body instead of PEEK January 15, 2014 04:33PM |
Re: J-head with ceramic body instead of PEEK January 15, 2014 05:13PM |
Re: J-head with ceramic body instead of PEEK January 15, 2014 05:22PM |
Re: J-head with ceramic body instead of PEEK January 15, 2014 05:42PM |
Re: J-head with ceramic body instead of PEEK January 15, 2014 05:50PM |
Re: J-head with ceramic body instead of PEEK January 15, 2014 05:56PM |
Re: J-head with ceramic body instead of PEEK January 15, 2014 05:57PM |
Re: J-head with ceramic body instead of PEEK January 15, 2014 06:04PM |
dave3d
I thought about why not just a solid block of ptfe? the same shape as the peek jhead.
Must be a reason why not.
Re: J-head with ceramic body instead of PEEK January 15, 2014 06:17PM |
Re: J-head with ceramic body instead of PEEK January 15, 2014 06:32PM |
aduy
PTFE becomes soft at printing temps so it can't be structural.
My current hot end is basically a Bowden tube attached to the nozzle. The heater block slips on around the nozzle, the nozzle screws onto a piece of stainless that has a hole for the PTFE to go through. The stainless is held between two pieces of phenolic, which is attached to another piece of phenolic with some standoffs. The ptfe tube is cooled just above the stainless piece. Its basically the water cooled version of the sg2. You could probably machine a stainless tube to fit in place of the PTFE if you wanted to go higher than 280
Re: J-head with ceramic body instead of PEEK January 15, 2014 10:50PM |
Anonymous User
Re: J-head with ceramic body instead of PEEK January 15, 2014 11:01PM |
Re: J-head with ceramic body instead of PEEK January 15, 2014 11:12PM |
Re: J-head with ceramic body instead of PEEK January 16, 2014 01:11AM |
Re: J-head with ceramic body instead of PEEK January 16, 2014 12:25PM |
Re: J-head with ceramic body instead of PEEK January 16, 2014 01:18PM |
Re: J-head with ceramic body instead of PEEK January 17, 2014 01:21AM |
Re: J-head with ceramic body instead of PEEK January 26, 2014 01:10AM |
Re: J-head with ceramic body instead of PEEK January 26, 2014 05:35AM |
Re: J-head with ceramic body instead of PEEK January 26, 2014 05:43AM |
Admin Registered: 11 years ago Posts: 1,063 |
Re: J-head with ceramic body instead of PEEK January 26, 2014 06:18AM |
Re: J-head with ceramic body instead of PEEK January 26, 2014 08:52AM |
Ohmarinus
Just to be clear, it's Ceramic Zirconium.
My concern was that Zirconium becomes brittle when it is exposed to heat for consecutive long periods of time. I would stay with PEEK.
Rulon might be a good material:
[tetw.org]
Re: J-head with ceramic body instead of PEEK January 26, 2014 08:54AM |
dave3d
Glass conducts heat too well. The heat from the hotend would be transfered to the x carriage.
Re: J-head with ceramic body instead of PEEK January 26, 2014 09:09AM |
Anonymous User
Re: J-head with ceramic body instead of PEEK January 26, 2014 11:35AM |
reifsnyderb
Early hot-end designs used PTFE and brass. The PTFE was known to fail rather quickly as PTFE makes a poor support material.
Re: J-head with ceramic body instead of PEEK January 26, 2014 11:40AM |
Re: J-head with ceramic body instead of PEEK January 26, 2014 02:28PM |
Anonymous User
Re: J-head with ceramic body instead of PEEK January 26, 2014 03:01PM |
