Thermal Putty for Thermistor/Thermocouple January 17, 2014 01:08PM |
Re: Thermal Putty for Thermistor/Thermocouple January 17, 2014 01:41PM |
Re: Thermal Putty for Thermistor/Thermocouple January 17, 2014 01:44PM |
TheyCallMeJohn
I recently had to put a new heater block on my printer after I ruined the old one. While I was doing it I added some Thermal paste from Fry's (I think it was EARCH:MAIN_RSLT_PG" target="_blank" rel="nofollow">Masscool Stars-700 Thermal Paste. While I didn't record or take any screen shots before, to me it seem like my temp is more consistent. I was warned to make sure not to get the thermal paste on the wires coming out of the resistor so as to not short circuit it.
As for thermal grease, when I was at Fry's the tech did not recommend it. He looked at what I was doing and said it was far liquid and would likely run out.
On a side not make sure you use some anti seize if you are putting together threaded components. I used some spark plug anti-seize thread protector paste from PepBoys. Though one of these substance released some steam/smoke when the hotend heated up for the first time.
Re: Thermal Putty for Thermistor/Thermocouple January 17, 2014 02:20PM |
Re: Thermal Putty for Thermistor/Thermocouple January 17, 2014 02:32PM |
Admin Registered: 12 years ago Posts: 3,096 |
Re: Thermal Putty for Thermistor/Thermocouple January 17, 2014 02:39PM |
Re: Thermal Putty for Thermistor/Thermocouple January 17, 2014 02:52PM |
Re: Thermal Putty for Thermistor/Thermocouple January 17, 2014 08:45PM |
TheyCallMeJohn
Could you put the whole thing in high temp heat shrink tubing (rated to 260C to keep the parts in?
[www.cableorganizer.com]
It would be kind of an expensive solution unless you could buy it in short pieces.
Re: Thermal Putty for Thermistor/Thermocouple January 18, 2014 01:15AM |
Re: Thermal Putty for Thermistor/Thermocouple January 18, 2014 11:03AM |
Xabbax
I use Braided Fiberglass Sleeving Impregnated With Silicone - one on each wire - must be the silicone impregnated tubes - not other plastics
[www.alibaba.com]
Re: Thermal Putty for Thermistor/Thermocouple January 19, 2014 01:59AM |
Re: Thermal Putty for Thermistor/Thermocouple January 19, 2014 12:28PM |
tjb1
[shop.advanceautoparts.com]
I found that locally and it seems to be roughly the same as the mcmaster stuff, I will go get it and try it out. I'm trying to eliminate my thermocouple swings and there is quite a bit of air around the thermocouple.
Re: Thermal Putty for Thermistor/Thermocouple January 19, 2014 04:28PM |
Re: Thermal Putty for Thermistor/Thermocouple January 19, 2014 05:01PM |
Admin Registered: 18 years ago Posts: 14,154 |
Re: Thermal Putty for Thermistor/Thermocouple January 20, 2014 02:14PM |
Re: Thermal Putty for Thermistor/Thermocouple May 01, 2014 02:34PM |
Re: Thermal Putty for Thermistor/Thermocouple May 04, 2014 02:27PM |
I've used them with another µC (ADuC847) with a builtin 24Bit AD-converter 'straight forward' as linear sensor with a simple voltage-to-temp conversion/calculation. For controlling the temperature accurate to 0.02°C we had a sort of PID, but you can run it as bang-bang too ...
Re: Thermal Putty for Thermistor/Thermocouple May 04, 2014 06:39PM |
Xabbax
[www.alibaba.com]
Re: Thermal Putty for Thermistor/Thermocouple May 04, 2014 11:47PM |
Re: Thermal Putty for Thermistor/Thermocouple May 05, 2014 04:25AM |
Re: Thermal Putty for Thermistor/Thermocouple May 05, 2014 10:16AM |
Re: Thermal Putty for Thermistor/Thermocouple May 07, 2014 10:57AM |
*(T)*(T)))-12.00) // ***here, add brackets also|
Re: Thermal Putty for Thermistor/Thermocouple May 07, 2014 01:42PM |
Re: Thermal Putty for Thermistor/Thermocouple May 07, 2014 03:24PM |
Re: Thermal Putty for Thermistor/Thermocouple May 08, 2014 09:42AM |
Re: Thermal Putty for Thermistor/Thermocouple May 08, 2014 09:59AM |
Re: Thermal Putty for Thermistor/Thermocouple May 08, 2014 02:37PM |
MrDoctorDIV
I don't know how the solidoodle thermistor is placed, but when I got my E3D I wanted perfection so I put plain thermal paste to fill the hole the thermistor was in [and to increase contact between heater and block] and the temp read differences are scary. Where I would go 162 perfectly fine on my SD hotend, with the E3D upgrade I need to go at least 220C, else it won't extrude properly even at super slow speeds. I've gone to 350C just fine with the thermal paste. Heating is instant, there is absolutely no delay between pressing the heater button and the rise in detected temp. Heck, if it's just sitting there cold, as soon as I grab the hotend it shows a rise in temp. The readings are not only accurate, they're wicked fast.
Re: Thermal Putty for Thermistor/Thermocouple May 08, 2014 03:46PM |
