Marlin Firmware Problem January 17, 2014 04:02PM |
rinter stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)|
Re: Marlin Firmware Problem January 17, 2014 04:04PM |
Re: Marlin Firmware Problem January 17, 2014 04:40PM |
Re: Marlin Firmware Problem January 17, 2014 05:12PM |
jamesdanielv
check your thermister connections. the error is a heater fault.
ShadowRam
Your minimum temperature alarm has been set off.
Change your configuration.h to these values.
#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_BED 1
#define HEATER_0_MINTEMP 5
#define HEATER_1_MINTEMP 0
#define HEATER_2_MINTEMP 0
#define BED_MINTEMP 5
This enables sensors for Extruder 1 and Bed. (Assuming 100k Thermisistor)
And sets the minimum temperature to 5deg C.
Re: Marlin Firmware Problem January 17, 2014 11:09PM |
Re: Marlin Firmware Problem January 18, 2014 03:21PM |
ShadowRam
What is the resistance of your Thermsistor not connected to anything?
Re: Marlin Firmware Problem January 18, 2014 06:06PM |
