Replacing steel & lmxuu with aluminium & plastic January 20, 2014 04:53AM |
Re: Replacing steel & lmxuu with aluminium & plastic January 20, 2014 05:16AM |
Re: Replacing steel & lmxuu with aluminium & plastic January 20, 2014 11:08AM |
Re: Replacing steel & lmxuu with aluminium & plastic January 20, 2014 01:43PM |
Re: Replacing steel & lmxuu with aluminium & plastic January 20, 2014 04:20PM |
gmh39
There is a thread on here somewhere about someone using printed parts (PLA?) along aluminum extrusion to act as a linear rail. It seemed that they got some pretty good results.
Re: Replacing steel & lmxuu with aluminium & plastic January 20, 2014 05:17PM |
ddseeker
gmh39
This thread?
Re: Replacing steel & lmxuu with aluminium & plastic January 20, 2014 05:19PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Replacing steel & lmxuu with aluminium & plastic January 21, 2014 05:29AM |
Re: Replacing steel & lmxuu with aluminium & plastic January 21, 2014 09:14AM |
Re: Replacing steel & lmxuu with aluminium & plastic January 21, 2014 10:55AM |
gmh39
lmxuu bearings and rails provide most consistency in fitment. yea, sure you might get the odd bearing that has a bit more slop or is more noisy, but overall it is easier. You just buy bearings/rod and assemble.
The PLA printed parts require precision dimensional accuracy. If there is like a millimeter of slop in your slides, it will affect your print quality. So you need to print your sliding parts out on a highly tuned, highly precise printer.
