Printing with the new t-glase from taulman3d January 27, 2014 10:50PM |
Re: Printing with the new t-glase from taulman3d January 27, 2014 10:59PM |
Re: Printing with the new t-glase from taulman3d January 27, 2014 11:44PM |
Re: Printing with the new t-glase from taulman3d January 28, 2014 12:46AM |
Re: Printing with the new t-glase from taulman3d January 28, 2014 01:00AM |
Re: Printing with the new t-glase from taulman3d January 28, 2014 09:01AM |
Re: Printing with the new t-glase from taulman3d January 28, 2014 09:14AM |
Antslake
Oh! one very important tip, because if you are half witted like me, you might miss it. The spools come with some netting on them....DO NOT TAKE OFF THE netting. It will quickly unravel, and you will have a mess. The filament is meant to feed out from under the netting. Same thing with the nylon spools. Make sure your spring tension for your idler is good and tight, and that your extruder motor is tuned!
Re: Printing with the new t-glase from taulman3d January 28, 2014 08:44PM |
uGen
From your images, the t-glase looks quite pretty and the more complex objects are rather intriguing due to the translucency.
I have a spool of PET from plastic2print which also prints very nicely - it is very transparent like glass and getting it to stick to the heated bed is very easy. However, the PET is very brittle and will shatter (or more like explode) into a million pieces when hit with a hammer - like glass or a big chunk of sugar. It also gets soft at about >=60°C...
As it seems, the taulman product is far less brittle (the vice test you did would have already completely devastated the other PET). So the higher cost might be justified for mechanical applications...
Do you know at which point the t-glase gets soft? I am currently in the process of choosing a filament with which one could print the frame of a small printer like the tantillus and would like to have a heated or IR chamber (which is insulated, so the plastic frame isn't directly in contact with the hot air or IR radiation).
Re: Printing with the new t-glase from taulman3d January 29, 2014 05:54AM |
Re: Printing with the new t-glase from taulman3d February 02, 2014 04:14PM |
Re: Printing with the new t-glase from taulman3d February 03, 2014 04:54PM |
Re: Printing with the new t-glase from taulman3d February 03, 2014 05:45PM |
Re: Printing with the new t-glase from taulman3d February 03, 2014 09:51PM |
Re: Printing with the new t-glase from taulman3d February 03, 2014 09:56PM |
Re: Printing with the new t-glase from taulman3d February 04, 2014 03:13AM |
Re: Printing with the new t-glase from taulman3d February 06, 2014 08:50AM |
Re: Printing with the new t-glase from taulman3d February 13, 2014 02:27PM |
MiguelKendrick
Taulman T-Glass is one of my favourite, I'm personally using this: --Link Removed--. It has a brilliant luster and great complimentary industrial material. To stay away from any hassle, always follow the standard heated platform when printing Taulamn (temperature of 110C and a Nozzle temperature of 212C).
Re: Printing with the new t-glase from taulman3d February 13, 2014 06:34PM |
Re: Printing with the new t-glase from taulman3d February 13, 2014 08:54PM |
Re: Printing with the new t-glase from taulman3d February 14, 2014 02:10PM |
Re: Printing with the new t-glase from taulman3d March 30, 2014 04:07PM |
Re: Printing with the new t-glase from taulman3d June 29, 2014 06:35PM |
