a replacement for peek (solved)
a replacement for peek (solved) January 28, 2014 07:48AM |
Re: a replacement for peek (solved) January 28, 2014 08:26AM |
Re: a replacement for peek (solved) January 28, 2014 09:12AM |
Re: a replacement for peek (solved) January 28, 2014 12:01PM |
and cheap.
Re: a replacement for peek (solved) January 28, 2014 12:14PM |
Admin Registered: 12 years ago Posts: 3,096 |
Re: a replacement for peek (solved) January 28, 2014 01:43PM |
Re: a replacement for peek (solved) January 28, 2014 02:28PM |
Re: a replacement for peek (solved) January 28, 2014 04:31PM |
Here: Section 5: Autoignition Temperature: 1103 F./ 595 CQuote
blackline
and yes there are issues with wood, but not with this wood, i don't now how about your info, but PEEK have a cont. bout 220° and a peak of 330°
I'm not sure what your source is for a A1 rating. I can't find an authorative source, as in non-marketing literature or posts on various forums that can substantiate that Ipe has that rating. I'm not even sure what an A1 (or also seen as A-1) means. Maybe it's a national or European rating. Here in the US, we have a NFPA rating of just "A" which indicates it has minimal flame spread. An A-rating doesn't mean it won't combust. Gypsum board (aka drywall) for instance also has an A rating. If it's wood, it will burn, period. It isn't likely to catch fire with just a spark or a standard match for instance. But put a enough of a constant heat source under or next to it for a long period of time and it most defintiely will start to char or otherwise deteriorate. Here is a discussion elsewhere with people discussing how hot Ipe burns in their wood stoves.Quote
It is naturally fire resistant and has been awarded an 'A1' rating, like metal
Re: a replacement for peek (solved) January 28, 2014 06:18PM |
Anonymous User
Re: a replacement for peek (solved) January 28, 2014 07:02PM |
