Carbon Fiber 3D printer January 28, 2014 08:33PM |
Re: Carbon Fiber 3D printer January 28, 2014 08:49PM |
Anonymous User
Re: Carbon Fiber 3D printer January 28, 2014 08:59PM |
Re: Carbon Fiber 3D printer January 29, 2014 06:16AM |
gmh39
That's awesome! I would totally buy that. I wonder how he prints the CF, since typically it needs to be soaked with some kind of epoxy then vacuum sealed.
Re: Carbon Fiber 3D printer January 29, 2014 08:38AM |
vreihen
gmh39
In mass production settings, carbon fiber comes in "prepreg" weave, where the manufacturer soaks the material in a special epoxy formulation that doesn't harden until heated in an autoclave (under vacuum) per a specified ramp temperature time/curve chart. Many need to be kept in a refrigerator for long-term storage. The benefit is that you can get the best carbon-to-resin ratio this way, and it is easy to lay out in molds.
From the cutaway picture, this printer appears to be laying down a continuous carbon fiber yarn/filament, like a filament winder for making CF tubes. With some sort of continuous prepreg CF yarn/filament being heat-triggered by the extrusion nozzle, it doesn't seem implausible to lay a *continuous* bead of CF yarn/filament down with a little tweaking to a 3D printer.....
Re: Carbon Fiber 3D printer January 29, 2014 09:33AM |
Re: Carbon Fiber 3D printer January 29, 2014 02:56PM |
Re: Carbon Fiber 3D printer January 29, 2014 07:33PM |
Re: Carbon Fiber 3D printer January 29, 2014 08:06PM |
Buback
it will be stronger than typical pla or abs or whatever, but it's still got the same issues with inter-layer strength, i assume.
Re: Carbon Fiber 3D printer January 29, 2014 08:15PM |
Re: Carbon Fiber 3D printer August 24, 2014 10:26AM |
Re: Carbon Fiber 3D printer August 24, 2014 07:50PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Carbon Fiber 3D printer September 06, 2014 03:00AM |
Re: Carbon Fiber 3D printer February 16, 2015 03:51PM |
Re: Carbon Fiber 3D printer September 12, 2015 08:09PM |
Re: Carbon Fiber 3D printer September 14, 2015 12:08AM |
arnab05
even i am curious about the mechanism he uses to cut a yarn at the end of a layer.
Re: Carbon Fiber 3D printer September 14, 2015 05:01AM |
Re: Carbon Fiber 3D printer September 21, 2015 10:18PM |
Re: Carbon Fiber 3D printer September 22, 2015 05:44AM |
