Re: Electroplating ABS prints from Prusa i3 - Problems February 03, 2014 03:11PM |
Re: Electroplating ABS prints from Prusa i3 - Problems February 03, 2014 03:44PM |
Re: Electroplating ABS prints from Prusa i3 - Problems February 03, 2014 05:33PM |
Re: Electroplating ABS prints from Prusa i3 - Problems February 03, 2014 05:52PM |
Re: Electroplating ABS prints from Prusa i3 - Problems February 04, 2014 02:56AM |
JimG
As a graduate chemist my take on this recipe is:-
based on volumes take
1 litre of water (use distilled water for this)
1 litre of Phosphoric acid (pure concentrated acid)
2.5 litres of concentrated Sulphuric acid (the molarity given around 18M or 18 moles per litre is that of concentrated acid)
Then for every litre add 60g of Manganese dioxide (MnO2) so for the full 4.5 litres use 270g of the dioxide.
You can use smaller quantities as long as you keep it to the same ratio 1:1:2.5 for the liquids and the equivalent quantity of MnO2.
Now for the safety aspects. Do not under any circumstances add the water to the conc sulphuric acid. Always wear good eye protection and if you can a rubber or PVC apron while mixing these chemicals.
I would recommend that you measure out your water then slowly add the sulphuric acid preferably while using a stirrer. Allow this to cool down as the mixing will produce a lot of heat. Once cool slowly add the phosphoric acid while stirring, again allow to cool then you can add the MnO2 while stirring. I am not sure just how much will dissolve as MnO2 is classed as insoluble, you may just get the powder suspended in the liquid.
The resulting mixture will be very corrosive so great care must be taken while using it wear good splash proof eye protection and PVC gloves to protect your hands, a PVC apron to protect clothing against splashes would also be a good idea.
Hope this is of some use to you.
Jim
Re: Electroplating ABS prints from Prusa i3 - Problems March 17, 2014 12:35PM |
Re: Electroplating ABS prints from Prusa i3 - Problems March 17, 2014 01:39PM |
Re: Electroplating ABS prints from Prusa i3 - Problems March 17, 2014 02:39PM |
Re: Electroplating ABS prints from Prusa i3 - Problems March 17, 2014 05:21PM |
Re: Electroplating ABS prints from Prusa i3 - Problems March 18, 2014 02:47AM |
JimG
Re: Electroplating ABS prints from Prusa i3 - Problems March 18, 2014 11:20AM |
Re: Electroplating ABS prints from Prusa i3 - Problems March 18, 2014 12:55PM |
Re: Electroplating ABS prints from Prusa i3 - Problems March 18, 2014 01:36PM |
Re: Electroplating ABS prints from Prusa i3 - Problems April 13, 2014 07:11AM |
[www.3ddc.eu]Quote
[plating 3d printed parts exhibited a] 10 fold increase in stiffness.
The coated models closely replicate traditional carbon fibre parts.
Re: Electroplating ABS prints from Prusa i3 - Problems April 13, 2014 12:29PM |
Re: Electroplating ABS prints from Prusa i3 - Problems May 27, 2014 08:31PM |
Re: Electroplating ABS prints from Prusa i3 - Problems May 28, 2014 11:26AM |
Re: Electroplating ABS prints from Prusa i3 - Problems May 29, 2014 02:06PM |
Re: Electroplating ABS prints from Prusa i3 - Problems May 29, 2014 02:34PM |
Re: Electroplating ABS prints from Prusa i3 - Problems May 29, 2014 03:14PM |
Re: Electroplating ABS prints from Prusa i3 - Problems May 29, 2014 03:21PM |
Re: Electroplating ABS prints from Prusa i3 - Problems May 29, 2014 06:45PM |
Re: Electroplating ABS prints from Prusa i3 - Problems May 29, 2014 09:16PM |
Re: Electroplating ABS prints from Prusa i3 - Problems May 30, 2014 08:55AM |
Re: Electroplating ABS prints from Prusa i3 - Problems May 31, 2014 11:49PM |
Re: Electroplating ABS prints from Prusa i3 - Problems June 01, 2014 12:01AM |
Re: Electroplating ABS prints from Prusa i3 - Problems June 03, 2014 08:29AM |
Re: Electroplating ABS prints from Prusa i3 - Problems March 26, 2015 12:39AM |
Re: Electroplating ABS prints from Prusa i3 - Problems March 26, 2015 11:18AM |
Re: Electroplating ABS prints from Prusa i3 - Problems August 16, 2015 08:23PM |
