Why is an acme rod good? February 03, 2014 09:11AM |
Re: Why is acme rod good? February 03, 2014 09:21AM |
Re: Why is acme rod good? February 03, 2014 09:40AM |
Re: Why is acme rod good? February 03, 2014 11:06AM |
Re: Why is acme rod good? February 03, 2014 11:18AM |
Re: Why is acme rod good? February 03, 2014 12:56PM |
Re: Why is acme rod good? February 03, 2014 02:10PM |
Re: Why is acme rod good? February 03, 2014 02:21PM |
Re: Why is acme rod good? February 03, 2014 04:03PM |
Re: Why is acme rod good? February 03, 2014 04:45PM |
Re: Why is acme rod good? February 03, 2014 05:46PM |
Re: Why is acme rod good? February 03, 2014 10:14PM |
Anonymous User
Re: Why is acme rod good? February 03, 2014 10:24PM |
Re: Why is acme rod good? February 03, 2014 11:06PM |
Anonymous User
Re: Why is acme rod good? February 03, 2014 11:19PM |
Re: Why is acme rod good? February 03, 2014 11:40PM |
Re: Why is acme rod good? February 03, 2014 11:43PM |
Re: Why is acme rod good? February 04, 2014 12:19AM |
Re: Why is acme rod good? February 04, 2014 12:34AM |
Re: Why is acme rod good? February 04, 2014 02:40AM |
Re: Why is acme rod good? February 04, 2014 04:49AM |
cnc dick
Jpan asked specifically about Acme threaded rods helping z wobble and he was the one that started the post. Ralf posted a picture which is definitely Z banding and not z wobble
Re: Why is acme rod good? February 04, 2014 04:53AM |
Re: Why is acme rod good? February 04, 2014 08:20AM |
Re: Why is acme rod good? February 04, 2014 05:30PM |
Re: Why is acme rod good? February 04, 2014 08:31PM |
akhlut
... As best I can figure out, calibrating the Z- axis means you'll create oddball ideal layer heights. By that I mean your full-step layer heights will have more than 3 significant digits. This introduces the error.
Example:
You have an M6 rod that has a 1mm pitch, 200 step motors and they're driven @ full step. That's a Z-axis value of 200 in firmware, and the ideal layer height will be a multiple of 0.005mm - this is perfect. So let's calibrate the axis, and say that it takes 199 steps to go 1mm. That means your ideal layer height is a multiple of 0.00502512562814070351758793969849. This is a problem, as slic3r cannot use it as a layer height.
So it's not just a z-axis issue. It's a calibration issue, a slicing issue, a layer-height choice issue and possible a z-wobble issue, all rolled up into one problem. D:
Re: Why is acme rod good? February 04, 2014 08:48PM |
Re: Why is acme rod good? February 04, 2014 08:57PM |
akhlut
Yeah. I dont bother with microstepping on z because there is no point. As far as calibrating z that is exactly what im advocating - dont measure, just plug the ouput drom the equation pitch/(stepper resolution×microstep rate).
Re: Why is an acme rod good? February 05, 2014 11:04PM |
Re: Why is an acme rod good? February 05, 2014 11:48PM |
Re: Why is an acme rod good? February 08, 2014 03:56PM |
