Re: Why is an acme rod good? February 08, 2014 06:31PM |
Re: Why is an acme rod good? February 08, 2014 07:42PM |
Re: Why is acme rod good? February 08, 2014 07:59PM |
Ralf
Still if you look closely at the print, you will see that the layers is not shifted sideways.
The above print was one of the first I printed on my all steel repstrap, with 16mm hardened smooth rods. The z leadscrews is only suspended in one end, so there is no way that they would be able to push the y carrige arount to cause that ammount banding.
At the time I struggled with the problem, the compresion effect was confirmed using a dial indicator, raising the z height 0.1mm at the time. This revealed travel between 0.08mm and 0.12mm, however every full revolution of the z leadscrews it measured spot on. Also there was no dectable lateral movement of the y carrige, when changing the z height.
