Replace extruder with a Spray Valve February 05, 2014 01:35PM |
Re: Replace extruder with a Spray Valve February 05, 2014 03:10PM |
first off what you trying to build a T-shirt printer not assembled you could use any of the mechanical kits without the electronics. And then use Mach 3 CNC software and buy drivers and set up a relay on off like the spindle would be on a milling machine or router. Or any of the cheap small CNC routers you see on eBay or whateverQuote
ajmartin
Hello,
I am looking for a pre built printer that is easily modifable. I want to replace the extruder with a Spray Valve that I will control with the signal that usualy controls the extruder. The spray will be room temperture so I also need to modify the printer to not look at extruder temperature or advancment. Is there any recomendation for a very well documented eaisly modifable printer that people are hacking?
Alan
Re: Replace extruder with a Spray Valve February 05, 2014 03:22PM |
Re: Replace extruder with a Spray Valve February 05, 2014 03:44PM |
Re: Replace extruder with a Spray Valve February 05, 2014 03:49PM |
Re: Replace extruder with a Spray Valve February 05, 2014 04:09PM |
Re: Replace extruder with a Spray Valve February 05, 2014 06:06PM |
Re: Replace extruder with a Spray Valve February 05, 2014 07:58PM |
Anonymous User
Re: Replace extruder with a Spray Valve February 05, 2014 10:25PM |
Re: Replace extruder with a Spray Valve February 06, 2014 12:34AM |
