Heatbed slow in heating
February 24, 2014 12:03PM
Hello everyone,
I have a Prusa I3 printer which is working very fine. But I have a horrible time to wait until my heatbed is on temperature. Sometimes I have to wait for 45 minutes to come to a 110 degrees Celsius. I have chenged the wiring to thick ones, but doesn't fix it.
The heatbed is connected to a Megatronics V2 board with 12V output tot the heatbed. Almost no drop of voltage to the heatbed. Thermistor reading is good.
Does anyone has a suggestion to get this solved to a faster heating time?
Re: Heatbed slow in heating
February 24, 2014 02:47PM
What's the resistance of your heated bed? Should be in the 1 to 1.2 Ohm range for optimal heating.
February 24, 2014 03:45PM
What Amp rating is your PSU? It could be that it isn't high enough to power the heat bed quickly.
February 25, 2014 02:50AM
do you use a thermal insulator under your heatbed?
[www.ebay.com]
February 25, 2014 06:49AM
also check the voltage both at the bed and at the psu. You would be supprised how much difference there can be running at 11.5v rather than 12v
Edited 1 time(s). Last edit at 02/25/2014 06:51AM by lazzymonk.
February 25, 2014 03:34PM
lazzymonk
In the Dutch forum I read that the voltage of Hill's PSU drops 0.25v when heating up.
Edited 1 time(s). Last edit at 02/25/2014 03:35PM by Ohmarinus.
