LED #4 on ramps 1.4 and very long wait time for heat bead to start up February 26, 2014 06:59PM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up February 26, 2014 07:09PM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up February 26, 2014 07:13PM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up February 26, 2014 07:53PM |
Admin Registered: 17 years ago Posts: 1,472 |
gilsah
It takes about 5 min before it will start to heat.
gilsah
The LED on the board and LED #4 on ramps blink at the same time but not always in the same pattern.
gilsah
Also it will drop about 30 degrees before it starts to heat up again?
gilsah
I have good power supply so I'm thinking it might be in sprinter.
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up February 26, 2014 08:28PM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up February 26, 2014 09:13PM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up February 26, 2014 10:10PM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up February 26, 2014 10:11PM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up February 27, 2014 03:41AM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up February 27, 2014 10:25AM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up February 27, 2014 05:48PM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up February 27, 2014 07:06PM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up February 27, 2014 09:18PM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up February 27, 2014 11:04PM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up February 27, 2014 11:31PM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up February 27, 2014 11:47PM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up March 01, 2014 11:14PM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up March 03, 2014 09:24AM |
gilsah
Ok I think I've lost 1/2 my hair today and the rest turned gray!! So I switched to mirlin firmware. And repetier after all day calibrating and running tests I think I figured out that it don't matter if you are extruding 20mm when you call for 20mm it's how the print looks. So while trying to change the settings I got a heat bed error saying it was over temp! Now it will not show a temp at all just 0c so I moved it to the extruder temp sensor and it shows proper temp so thermistor is good but now I'm at loss again.
Oh and still had the led #4 doing same thing.
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up March 03, 2014 11:00PM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up March 18, 2014 09:24PM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up March 18, 2014 09:45PM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up March 18, 2014 09:47PM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up March 18, 2014 09:55PM |
Re: LED #4 on ramps 1.4 and very long wait time for heat bead to start up March 18, 2014 10:20PM |
