A2A Printer Reviews??
Posted by metsj373
February 27, 2014 06:14PM
Hey, I am new to the 3D printing world and I am currently building a Prusa i2. Is A2A printing company a reliable source when it comes to buying parts. I am looking to get M8 threaded rods but want to make sure I get a nicely machined rod.
Re: A2A Printer Reviews??
February 28, 2014 08:35AM
There's no such thing as a "nicely machined" threaded rod. Their all just rolled threads which doesn't produce a straight rod nor produce a particularly accurate thread. You can get lucky and get nearly straight rods.
A2A will be sourcing their rod and from a supplier and not making it themselves. Your best bet is to get more than you need and find the least warped rods you can.
February 28, 2014 10:06AM
Use a smaller threaded rod, M5 or so and you won't have as many issues.
Edit: Sorry, I was thinking you were talking about the Z drive rods, not the entire printer.
Edited 1 time(s). Last edit at 02/28/2014 12:57PM by tjb1.
February 28, 2014 11:38AM
I swaped the 8mm for 5/16" for the threaded rods.. for the frame, there is no difference for the i2.
for the double Z-axis, there is a bit of a wobble because the nuts are a bit smaller than the 8mm ones.
the thing a did is tapped 8mm nuts to accomodate 5/16" threadings.. way not standard but works great.
March 01, 2014 01:51PM
using 5/16 threaded rod for the z-axis drive rods is a bad idea. You want to slice your models at full step heights. There are very few full step height options with a 5/16 rod. See the reprap magazine issue 1 or 2, I can't remember.
