"mendell" mcmaster carr part/order list (US) - simply paste into website December 21, 2009 03:51AM |
Re: "mendell" mcmaster carr part/order list (US) - simply paste into website December 28, 2009 10:39AM |
Re: "mendell" mcmaster carr part/order list (US) - simply paste into website January 10, 2010 11:28PM |
Re: "mendell" mcmaster carr part/order list (US) - simply paste into website January 11, 2010 01:50PM |
Re: "mendell" mcmaster carr part/order list (US) - simply paste into website March 17, 2010 01:23AM |
Re: "mendell" mcmaster carr part/order list (US) - simply paste into website March 17, 2010 06:11PM |
Re: "mendell" mcmaster carr part/order list (US) - simply paste into website March 17, 2010 09:26PM |
Re: "mendell" mcmaster carr part/order list (US) - simply paste into website March 18, 2010 12:58AM |
Re: "mendell" mcmaster carr part/order list (US) - simply paste into website March 19, 2010 12:12AM |
Re: "mendell" mcmaster carr part/order list (US) - simply paste into website March 19, 2010 03:21AM |
Re: "mendell" mcmaster carr part/order list (US) - simply paste into website March 19, 2010 07:38AM |
krafter
8888K41 - 5/16" bar, 3 feet length, A2 tool steel, $8.37 each
On the last item I am evaluating to see if the 5/16" bar works as a substitute for the 8mm stuff. Its pretty close
Re: "mendell" mcmaster carr part/order list (US) - simply paste into website March 19, 2010 09:37AM |
Re: "mendell" mcmaster carr part/order list (US) - simply paste into website March 19, 2010 02:13PM |
Re: "mendell" mcmaster carr part/order list (US) - simply paste into website March 19, 2010 08:24PM |
Re: "mendell" mcmaster carr part/order list (US) - simply paste into website March 23, 2010 01:04PM |
Re: "mendell" mcmaster carr part/order list (US) - simply paste into website March 23, 2010 06:44PM |
Re: "mendell" mcmaster carr part/order list (US) - simply paste into website March 25, 2010 01:57PM |
Re: "mendell" mcmaster carr part/order list (US) - simply paste into website April 16, 2010 07:11PM |
Re: "mendell" mcmaster carr part/order list (US) - simply paste into website April 16, 2010 09:19PM |
qty_o partnum $_p.u. q_need desc 1 91290A123 4.99 50 Metric Class 12.9 Socket Head Cap Screw Alloy Stl, M3 Thread, 20mm Length, 0.50mm Pitch 1 90591A121 1.33 18 Metric Zinc-Plated Steel Hex Nut Class 6, M3 Size, .5mm Pitch, 5.5mm W, 2.4mm H 1 90576A102 2.82 34 Metric Zinc-Plated Steel Nylon-Insert Locknut Class 6, M3 Screw Size, .5mm Pitch, 5.5mm W, 4mm H 2 93475A210 0.77 102 Metric DIN 125 18-8 SS Flat Washer M3 Screw Size, 7mm OD, 0.45mm-0.55mm Thick 1 90591A141 1.33 25 Metric Zinc-Plated Steel Hex Nut Class 6, M4 Screw Size, .7mm Pitch, 7mm W, 3.2mm H 2 90576A103 3.50 129 Metric Zinc-Plated Steel Nylon-Insert Locknut Class 6, M4 Sz, .7mm Pitch, 7mm Width, 5mm Height 5 93475A230 1.60 449 Metric DIN 125 18-8 SS Flat Washer M4 Screw Size, 9mm OD, 0.7mm-0.9mm Thick 1 91292A118 4.93 38 Metric 18-8 SS Socket Head Cap Screw M4 Thread, 16mm Length, 0.7mm Pitch 2 91290A184 9.96 115 Metric Class 12.9 Socket Head Cap Screw Alloy Stl, M4 Thread, 40mm Length, 0.70mm Pitch 1 91090A101 2.93 15 Zinc-Plated Steel Large-Diameter Flat Washer No. 8 Screw Size, 3/4" OD, .04"-.06" Thick 2 90591A161 4.83 104 Metric Zinc-Plated Steel Hex Nut Class 8, M8 Size, 1.25mm Pitch, 13mm W, 6.5mm H 2 91166A270 2.73 104 DIN 125 Zinc-Plated Class 4 Steel Flat Washer M8 Screw Size, 16mm OD, 1.4mm-1.8mm Thick 8 98861A080 2.27 8 Metric Class 4.6 Plain Steel Threaded Rod M8 Size, 1 Meter Length, 1.25 mm Pitch 3 88625K67 4.88 3 O1 Tool Steel Tight-Tolerance Rod 8 Millimeter Diameter, 3' Length 1 6484K512 5.22 1 Trapezoidal Tooth Neoprene Timing Belt .200" Pitch, Trade Sz 390XL, 39" Outer Circle, 1/4" W 8 7959K24 1.82 8 Trapezoidal-Tooth Neoprene Belting XL Trade Size, .200" Pitch, 1/4" Width 1 91290A125 7.09 4 Metric Class 12.9 Socket Head Cap Screw Alloy Stl, M3 Thread, 25mm Length, 0.50mm Pitch 1 91292A121 4.51 1 Metric 18-8 SS Socket Head Cap Screw M4 Thread, 20mm Length, 0.7mm Pitch
Re: "mendell" mcmaster carr part/order list (US) - simply paste into website April 18, 2010 12:22AM |
