Heat Bed Sizing March 05, 2014 03:41PM |
Re: Heat Bed Sizing March 05, 2014 04:03PM |
Admin Registered: 17 years ago Posts: 1,472 |
Re: Heat Bed Sizing March 05, 2014 04:19PM |
Re: Heat Bed Sizing March 05, 2014 04:54PM |
ARosch
Also, the 12x12 says up to 20A.
ARosch
I like the AC idea, but I want everything to run off one power supply and configuring that to work with RAMPS seems like it could be tricky?
Re: Heat Bed Sizing March 05, 2014 09:41PM |
Re: Heat Bed Sizing March 10, 2014 06:14AM |
Re: Heat Bed Sizing March 10, 2014 02:40PM |
Or just get a DC-DC SSR, and switch the output of the 12V supply rather than the AC input. This would probably be a lot cheaper than getting a new silicone heater rated for 230VAC. You should still be able to use PWM if the SSR supports it.Quote
RodF
Very interesting. I have a 12v 300mm x 300mm silicone heater which draws around 21 amps on my dc supply. So I have a SSR which I was going to turn the switch mode supply on and off with but a PWM on 230VAC seems a more elegant solution.
Re: Heat Bed Sizing March 10, 2014 04:16PM |
Re: Heat Bed Sizing May 09, 2014 09:18AM |
NewPerfection
I use a 12"x12" AC heated pad for my print bed (specifically, this one), and use an SSR to drive it from the regular heated bed output of my RAMPS board. This pad uses 360W, which still doesn't heat the aluminum and glass of my heated bed terribly quickly.
Re: Heat Bed Sizing June 28, 2014 02:55PM |
