having trouble will steppers binding on new build March 06, 2014 11:54PM |
Re: having trouble will steppers binding on new build March 07, 2014 01:19AM |
Re: having trouble will steppers binding on new build March 07, 2014 05:26AM |
Re: having trouble will steppers binding on new build March 07, 2014 11:39AM |
Admin Registered: 17 years ago Posts: 1,472 |
Re: having trouble will steppers binding on new build March 07, 2014 12:49PM |
Re: having trouble will steppers binding on new build March 07, 2014 04:59PM |
Re: having trouble will steppers binding on new build March 07, 2014 05:14PM |
Go ahead and run your printer as-is, you will just have to reduce the maximum speeds and accelerations that you run your machine at. You can print at slow speeds (20 mm/s or less) for now, which should produce acceptable parts, with maybe some oozing issues due to slow travel rates.Quote
aye_b_red_beard
While I am pouting, what would you suggest?
You are right that gearboxes would not be a good way to go, not least of which because they introduce complexity and backlash into the system. You can get reasonably small lead screws with over 20mm pitch, but they aren't cheap. See: [trinitylabs.com]Quote
aye_b_red_beard
I am thinking revamp x and y to a belt drive instead.
Gearboxes are not cost efficient and lead screws with a 20mm pitch or higher are way too large for my setup.
Re: having trouble will steppers binding on new build March 07, 2014 08:50PM |
