Printing temporary structures in another material March 07, 2014 04:42PM |
Re: Printing temporary structures in another material March 07, 2014 04:57PM |
Re: Printing temporary structures in another material March 07, 2014 05:06PM |
Admin Registered: 17 years ago Posts: 1,472 |
Yes, many people have tried this, including myself. It's still very experimental, but some people have had good success. PVA as support for PLA, PLA as support for ABS, and HIPS as support for ABS have all been successfully used.Quote
sclaes
It would be useful if temporary structures could be printed in another material: e.g. wax or a mixture of pla and wax. It would be a lot easier to remove those temporary structures after the object is printed. Has anyone tried this?
Just have separate .STL files for each material, at least until a better format is supported. Or, for a support material, have the slicer automatically generate the support material locations. Some slicers are better at this than others.Quote
sclaes
BTW: it requires some way of specifying which parts have to be printed using which material. AFAIK this is not possible with STL.
Not really. An automatic way of switching materials on each layer is needed, and it needs to be done reasonably quickly. With a single extruder and hot end, you would have to purge the remaining melted material from the hot end before printing with the new material, and you would still need some way of switching materials automatically. This would take a long time, make a mess, and waste material.Quote
sclaes
Another problem is changing material: is this possible without adding a second extruder?
Re: Printing temporary structures in another material March 07, 2014 05:26PM |
Re: Printing temporary structures in another material March 07, 2014 09:05PM |
