Power supply's March 08, 2014 08:37AM |
Re: Power supply's March 08, 2014 04:43PM |
Re: Power supply's March 09, 2014 07:43AM |
Re: Power supply's March 10, 2014 03:05PM |
Admin Registered: 15 years ago Posts: 1,470 |
A dedicated 12V, 16A power supply will do just fine on a printer with a proper-spec PCB heated bed and single extruder, assuming the power supply isn't a cheap, over-rated Chinese supply. I have built several printers with heated beds using 203W XBox 360 power supplies, which are ~17A at 12V.Quote
dissidence
i think that even at 20 amp your on the small side with the heated bed, i am using a 350 watt computer psu
This is normal for cheap ATX power supplies, and even some better ATX supplies without the 5V rail loaded at least a little bit. Two 12V, 5A power supplies would not handle the load either, and would sag in voltage, if not cut power completely.Quote
Enlightx
problem i have is voltage drops to 10V when heating up printer wanted to know if this is normal for power supply's.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: Power supply's March 10, 2014 05:43PM |
Re: Power supply's March 10, 2014 06:01PM |
Looks like I misread what you had written before. So, no heated bed? And you verified that the total amperage draw was less than 4A even when heating from cold? If your 12V 20A supply doesn't drop voltage with your i3 at 15A, it definitely shouldn't drop voltage at only 4A current draw.Quote
Enlightx
Currently testing on both 3DR and a Kissel so heated bed. Get same voltage drops on every psu I have atx, power brick, 12v 20a box.
Even tried a branded £15 12v 5a power pack with same results
Re: Power supply's March 11, 2014 02:42PM |
Re: Power supply's March 11, 2014 03:09PM |
And you've measured the current draw from the power supply when the voltage has sagged that much? I just don't see how it's possible for a 4A load to drop a 12V 20A power supply to 10V, unless there is a short, in which case the load would be much greater than 4A. Can you unplug the hot end heater and measure the resistance across it?Quote
Enlightx
yeah drops to 10V when heated the hotend just after homing. then when pwm kicks in (approx 10C before target temp) it goes back up to 12v.
iv noticed it for a while as you can hear fans on the machine tone down then back up again.
Re: Power supply's March 11, 2014 05:25PM |
