Z Axis troubles March 08, 2014 02:38PM |
Re: Z Axis troubles March 08, 2014 02:51PM |
kfootball15
I am having a problem with my Z axis.
Everything else on my printer works perfectly fine except for my Z-axis, which makes a loud grinding noise whenever I try to move it up or down.
I've tried re-soldering the connection to the plugs a million times to no success. I've even tried plugging it into the slot on the electronics right above it (not sure what its for) and I had the same results; a loud grinding noise.
Any idea how I could trouble shoot this problem? Is there a to test and see if the electronics may be broken?
Thanks,
Jeff
Re: Z Axis troubles March 08, 2014 06:55PM |
Re: Z Axis troubles March 08, 2014 07:28PM |
kfootball15
Thanks,
Jeff
Re: Z Axis troubles March 08, 2014 07:40PM |
Re: Z Axis troubles March 08, 2014 07:49PM |
Re: Z Axis troubles March 08, 2014 07:59PM |
waitaki
kfootball15
Thanks,
Jeff
Where exactly do you mean by the above?
Have you not got each motor plugged into its own Z receptacle?
Re: Z Axis troubles March 15, 2015 10:22PM |
Re: Z Axis troubles April 08, 2015 01:27PM |
Re: Z Axis troubles April 08, 2015 02:18PM |
