Marlin Have some kind of heating safety feature? March 09, 2014 01:02AM |
Re: Marlin Have some kind of heating safety feature? March 09, 2014 08:36AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Marlin Have some kind of heating safety feature? March 09, 2014 01:14PM |
kfootball15
Sometimes after I use my printer for a while, my electronics simply won't heat up my hotend. I'll let it rest for a while and it'll work fine again. Is this some kind of safety feature? Can I turn it off?
Re: Marlin Have some kind of heating safety feature? March 12, 2014 11:38PM |
Re: Marlin Have some kind of heating safety feature? March 13, 2014 01:45AM |
Re: Marlin Have some kind of heating safety feature? March 13, 2014 10:46AM |
bstott
RAMPS = Has an undersized Fuse and a poor chosen MOSFET. You will purchase a Fuse larger than 12A. I used a 14A fuse. You will also have to purchase a new MOSFET and replace. Once those two items are replaced you are good to go.
If your bed worked for a while before and now doesn't --- It is still likely related to these two components. My heated bed did work for a few tests then didn't. So I found, figured and performed the following fix. No worries all works great!
Where to find the information???
Here 1
Here2
More Here - Complete
The last link was how I fixed my issue. You can guess and debate with many people or simply fix the two components to work properly. Note: I used one MOSFET and others found slightly better selections for a MOSFET. Mine works well so you won't be wrong. The others simply may be feature wise better and run a couple degrees cooler. Either way you are much better off with this fix and should get to temperature easily. Read the threads and you will find the Polyfuse and MOSFET to buy. They are two parts and are through hole so easy to remove and solder. There are three pins on the MOSFET and two on the Fuse. If you do this simple fix - here is a tip. --- IF you are not really adept at removing soldered components simply cut the two existing parts off at their leads with wire cutters. Then heat with your soldering iron and remove their individual leads. Then, solder in the new components. You save A LOT of time this way.
Good Luck!
Brian.
