2 Heatbeds for the same Printer
March 11, 2014 03:59AM
Hey,
I have a Ramps 1.4 board and I am wanting to gain a bigger print area so I will combine 2 heatbeds together.
If I have a sufficiently high enough PSU Amps wise would, I be able to power both beds from the same OP? D8 on the ramps board?
my only concern is that i would pull to much current through the board it's self.
Thanks
NFireLabs - The World First Modular 3D Printer - At An Affordable Price!
Re: 2 Heatbeds for the same Printer
March 11, 2014 08:48AM
ayouden
Hey,
Thanks
The fuse on Ramps D8 line is an MFR1100 which has an 11amp hold rating and 22amp trip rating.
March 11, 2014 10:40AM
tjb1
Yep, not to mention that the connector on RAMPS isn't meant to handle that much current either.
You could just use a relay connected to D8 to control the power to the heated beds though.
March 11, 2014 05:33PM
You could also use external pid controllers which can be found for a decent price. That would be the easiest way to do it that I coukd think of. Its true that the traces on the ramps board wont handle that much amperage. Trying to do it with relays is possible and I would recommend using ssr instead of a mechanical relay if you go down that path but monitoring temps without an extra thermistor might get hairy. You would also have to change the firmware. I think your best bet would be to use external pid as it would save you a big headache.
--------------| For Everything |--------------------------
Check it out here:
[reprapsquad.wordpress.com].
---------| For Everything Prototype Related |------
Now featuring comp case mods:
[RepRapLab.wordpress.com]
--------------| Find us at Twitter|------------------------
@REPRAPSQUAD (RS Main)
[mobile.twitter.com]
@REPRAPSQUADHQ (ProtoLab)
March 11, 2014 06:29PM
REPRAP SQUAD
Um, what? You would monitor temps in exactly the same manner as if the power to the heated bed were running directly through RAMPS.
REPRAP SQUAD
No firmware changes necessary to use a relay, except maybe to disable bed PID/PWM if enabled and using a mechanical relay is desired.
REPRAP SQUAD
Not nearly as cheap as just getting a relay, especially since most PID controllers require (or come with) a relay anyways.
REPRAP SQUAD
Honestly, I think having an external PID controller that has to be manually set and controlled would be a bigger headache than just using a relay and letting your printer control the heated bed temperature.
In the end, an SSR that can handle the required amperage can be had for about $10, and is incredibly simple to wire up. No firmware changes should be necessary, and no bulky external PID controller to worry about.
