Print accuracy
Posted by Rigor_M
Print accuracy
March 14, 2014 10:38AM
This is more of a dilemma that I have in choosing a printer design.
I was wondering if prints are more accurate when the Bed is on the Z-axis (like the Ultimaker/2, replicator/2X) than when its on the Y-axis (Prusa i2/i3)
Then way I see it is, the part printing gets jerked around alot more when its on the y-axis.
the Z-axis one suffers only minimal drops /layer heights in movement.
Of coarse, i'm talking about higher speed prints.. lets say 80mm/s - 100mm/s.
I see that the Y-axis printers are very popular so that is why i'm asking.
anyone have a tough on this ?
J-F
Re: Print accuracy
March 14, 2014 11:50AM
I think a printer where the bed only moves on Z is far superior. I wouldn't even consider building a machine with a bed that moves in X or Y. You cold also consider a Delta bot which has a bed that does not move at all.
Re: Print accuracy
March 14, 2014 11:58AM
Sublime
Thanks for your reply.
i'm already at my 3rd printer design. The second one has a Z-Axis and I starting designing the 3rd one in the same matter and started thinking If I was making the best choice.
I have plans on building a Delta printer but a already made plan :-)
Thanks.
Re: Print accuracy
March 14, 2014 03:32PM
The best prints that I've seen are all from printers with the printbed on the Z-axis.
