I just ordered this but had not tested it yet, any feedback is appreciated. Will document any problems once I do the build in the next couple weeks. Just use the enter bulk order link on the mcmaster website.
---begin paste---
1 95462A033
1 91083A033
1 90275A714
1 90494A030
1 91083A030
1 90273A581
3 91034A100
1 98273A255
1 97828A633
2 8735K111
1 88805K57
1 51135K265
1 9001K34
1 9654K207
1 9429T34
3 4549K606
1 4549K595
2 4549K602
3 44605K115
1 68095K121
1 44605K155
2 44605K105
2 98847A029
---end paste----
Complete detail for informational purposes:
1 95462A033 1 Pack Zinc-plated Grade 5 Steel Hex Nut, 1/2"-13 Thread Size, 3/4" Width, 7/16" Height
2 91083A033 1 Pack Plain Steel Type A Sae Flat Washer, 1/2" Screw Size, 1-1/16" Od, .07"-.13" Thick
3 90275A714 1 Pack Zinc-pltd Stl Flat Head Slotted Machine Screw, 1/2"-13 Thread, 1-1/4" Length
4 90494A030 1 Pack Plain Grade 2 Steel Thin Hex Nut, 5/16"-18 Thread Size, 1/2" Width, 3/16" Height
5 91083A030 1 Pack Plain Steel Type A Sae Flat Washer, 5/16" Screw Size, 11/16" Od, .05"-.08" Thick
6 90273A581 1 Pack Zinc-plated Stl Flat Head Phil Machine Screw, 5/16"-18 Thread, 3/4" Length
7 91034A100 3 Each Black-oxide Steel Coupling Nut, 1/4"-20 Thread Size, 5/8" Length, 1/2" Width
8 98273A255 1 Pack 410 Ss Type 23 Thread-cutting Screw, 10-24 Thread, 1/2" Length
9 97828A633 1 Pack Plain Steel Brad Nails, 17 Gauge, 3/4" Length, 1900 Pcs/pk
10 8735K111 2 Ft. Bar Made Of Teflon(r) Ptfe, Rectangular Bar, 1/8" Thick, 1/2" Wide, 2' Length
11 88805K57 1 Each Architectural Aluminum (alloy 6063), 90 Deg Angle, 1/8" Thk, 1-1/2" X 1-1/2" Legs, 8' L
12 51135K265 1 Ft. High-temperature Silicone Rubber Tubing, Firm, 1/4" Id, 1/2" Od, 1/8" Wall, Blue, 1' L
13 9001K34 1 Each Architectural Aluminum (alloy 6063), U-channel, 1/8" Thk, 3/4" Base X 3/4" Legs, 8' L
14 9654K207 1 Pack Steel Extension Spring, Zinc-plated, 4" Length, 1/4" Od, .032" Wire
15 9429T34 1 Pack Steel Two-hole Clamp, For 11/16" Outside Diameter, 1/2" Emt Conduit
16 4549K606 3 Each Std-wall Galv Welded Steel Thrd Pipe Nipple, 3/4" Pipe, 12"l,thrded Ends,17/32"l Thread, Sch 40
17 4549K595 1 Each Std-wall Galv Welded Steel Thrd Pipe Nipple, 3/4" Sz, 3"l, Thrded Ends,17/32"l Thread, Sch 40
18 4549K602 2 Each Std-wall Galv Welded Steel Thrd Pipe Nipple, 3/4" Pipe, 6"l, Thrded Ends,17/32"l Thread, Sch 40
19 44605K115 3 Each Low-pressure Blk Malleable Iron Thrd Fitting, 3/4" Pipe Size, 90 Degree Elbow, 150 Psi
20 68095K121 1 Each Low-pressure Forged Steel Flange, Threaded, 3/4" Pipe Size X 3-7/8" Od, 150 Psi
21 44605K155 1 Each Low-pressure Blk Malleable Iron Thrd Fitting, 3/4" Pipe Size, Tee, 150 Psi
22 44605K105 2 Each Cast Iron,125 Psi,3/4"pipe,round Head Cap
23 98847A029 2 Each 18-8 Stainless Steel Threaded Rod, 1/4"-20 Thread, 3' Length
i am looking for MINIHELIC II VACUUM GAGE.
0 - 20 W.C.
MAX.PRESSURE 30PSIG.
PLEASE ADVISE THE CORRECT PART NUMBER TO ORDER.
