Need help building perhaps the biggest repstrap printer ever made! March 20, 2014 05:14AM |
Re: Need help building perhaps the biggest repstrap printer ever made! March 20, 2014 08:58AM |
Re: Need help building perhaps the biggest repstrap printer ever made! March 20, 2014 09:10AM |
Re: Need help building perhaps the biggest repstrap printer ever made! March 20, 2014 10:39AM |
I was planning on using PLA plastic, would printing bigger objects require a different filament?Quote
gmh39
What material did you want to print with?
What do you think would be be biggest I could make it without it requiring its own chamber?Quote
cnc dick
Building a large printer is not easy not too many people have been successful you will definitely need a heated enclosure. Which brings in a whole other set of problems keeping things cool that need to be inside the heated chamber such as the filament before it gets to the extruder hot end and the motors you're probably going to need water cooling for the hot end cold zone. The printer has to be extremely reliable because you going to print for extended periods of time 24 hours a day multiple days to complete large prints. Something that automatically pauses the print when a roll of filament runs out. I don't know what kind of skills and/or machinery you have but it's going to take a lot. To start off with I would build a small Kit there's a lot to learn. The machine has to be extremely strong it's not just like putting longer rods in a standard machine I might add very expensive unless you have a lot of stuff that you've acquired cheaply laying around. Larger motors which don't work well with the standard reprap electronics is another problem. I don't think the standard belts take heat that well so you're probably going to have to use high lead ballscrews which is what I did mine is only 17" x 14" x 14" . If It was easy they be a lot more large printers out there
Re: Need help building perhaps the biggest repstrap printer ever made! March 20, 2014 11:45AM |
Re: Need help building perhaps the biggest repstrap printer ever made! March 20, 2014 12:29PM |
Re: Need help building perhaps the biggest repstrap printer ever made! March 20, 2014 12:44PM |
Re: Need help building perhaps the biggest repstrap printer ever made! March 20, 2014 12:47PM |
Re: Need help building perhaps the biggest repstrap printer ever made! March 20, 2014 01:04PM |
Re: Need help building perhaps the biggest repstrap printer ever made! March 20, 2014 03:59PM |
