Want to build a Delta/Kossel/Rostock...
March 23, 2014 12:15AM
So after attending the Midwest RepRap Festival ( I was the dude with the Makerfarm i3!), I was inspired to build a new printer. After seeing all the sweet Delta-style printers I think that's what I want to build. Then I saw the Misumi deal....so my idea is this: I would like to build this new printer, but using some of the parts from my current Makerfarm printer, namely, the headed bed. Since the heated bed is bigger, how would I scale up a current Delta design? I'm not sure how to go about it. I did see another thread about the guy who converted his Printrbot Simple into a Delta, but I'm not that great with Solidworks just yet.
Also, it seems people with Delta printers are huge fans of 1.75mm filament. I suppose this is because it's easier on bowden-style extruders, but how hard is it to accomplish this with 3mm filament? I ask because I have a ton of it waiting to be used.
If I've posted in the wrong place, I apologize. I just thought if I posted here, more people would probably see it.
Re: Want to build a Delta/Kossel/Rostock...
March 23, 2014 04:45PM
i think the delta bots are cool, though i dont see why a guy would have to use 1.75mm filament, other than the lighter the hot end the better for a delta.
[mike-mack.blogspot.com]
March 23, 2014 08:13PM
Hey. I've got a makerfarm i3 also! I used my i3 to build a rostock delta printer. It has the same size heatbed as the markerfarm also. 3mm filament would work but 1.75 is more popular for bowden extruders.
March 23, 2014 08:26PM
gman
Where did you source the design? I've been looking, but I can't seem to figure out the proportions that I need to hit, i.e. how long do the arms have to be to reach the whole 8" x 8" bed? I'm trying to put together an order at Misumi before the end of the month and I don't want to order the wrong parts.
I figured that once I've printed myself out of 3mm filament, I could just convert everything to 1.75mm.
Edited 1 time(s). Last edit at 03/23/2014 08:27PM by dan11.
March 23, 2014 08:43PM
Here's the shopping list I made a while back. Some of the ebay links might be gone but also a lot of the things were bought from mcmasters. The dowels with the hinges need to be 25cm from the hinge hole to hinge hole. I built it to specification [reprap.org]
Electronics: ----------------------------------------------
RAMPS 1.4 or similar $60
[www.ebay.com]
Heatbed $17
[www.ebay.com]
NEMA 17 $60
[www.makerfarm.com]
micro switches $5
[www.makerfarm.com]
Other Parts: ----------------------------------------------
AluHotend $28
PFA Tube $7
[www.mcmaster.com]
Zip ties $3
[www.ebay.com]
Dowels
[www.ebay.com]
Fasteners: ------------------------------------------------
M3 Nuts $3
[www.mcmaster.com]
M3 washers $2
[www.mcmaster.com]
M3x12 mm screws $3
[www.mcmaster.com]
M3x16 mm screws $3
[www.mcmaster.com]
M3x20 mm screws $3
[www.mcmaster.com]
M4x40 mm screws for plywood mounting $8
[www.mcmaster.com]
M4 nuts $2
[www.mcmaster.com]
M8x35 mm screws for 608 ball bearings $8
[www.mcmaster.com]
M8 washers $3
[www.mcmaster.com]
Frame Parts: ----------------------------------------------
Baltic Birch PLywood x 3 $30
[www.amazon.com]
Motion: ---------------------------------------------------
GT2 $44
[www.ebay.com]
762x8 mm smooth rod $40
[www.mcmaster.com]
Part number: 5544T272
LM8UU linear bearing $13
[www.ebay.com]
608ZZ $8
[www.ebay.com]
March 23, 2014 09:31PM
Thanks!!!
I'm going to put in my order later this week.
